python import linuxcnc
- comjon
05 Mar 2016 18:52 #71091
by comjon
python import linuxcnc was created by comjon
From the Python API documentation, it appears "import linuxcnc" works for most people in a .py file if you install LinuxCNC from a LiveCD. I am integrating applications into my Ubuntu build, and added Python before I installed LinuxCNC.
Python can not find LinuxCNC modules (a.k.a. includes, libraries, you get the idea) and I therefore can not code with linuxcnc objects.
I have read a good bit about the "python setup.py install" command and what should be straightforward has become a beast. I need in simple language ideas how to get this module working in my .py file.
Thanks.
Thanks.
- comjon
08 Mar 2016 14:48 #71224
by comjon
Replied by comjon on topic python import linuxcnc
My plan at this time is: 1) build a fresh LinuxCNC install from the Live CD (I need to do this anyway on a new box, and. I can test whether a fresh install solves what I believe is an issue with dependencies on the box that spawned this thread. Once LinuxCNC is built, I will add Python IDE, then check if LinuxCNC is available as a module in Python by calling with "import linuxcnc ". If all goes well I can install the NINJA IDE.
- newbynobi
- Thank you received: 415
14 Mar 2016 09:40 #71615
by newbynobi
Replied by newbynobi on topic python import linuxcnc
@comjon
it does not matter if you install linuxcnc before or after python.
If import linuxcnc throws an error, than it is not included in your PYTHON_PATH
Where is the module installed?
And to what locations point your pythonpath?
Norbert
Norbert
- comjon
15 Mar 2016 12:12 - 15 Mar 2016 12:23 #71677
by comjon
Under "Project Properties" I added ~/git/LinuxCNC/
to the Custom Pythonpath dialogue.
This directory is the one from which I launch LinuxCNC in Terminal.
I am not certain of the name of the module I should add, is it LinuxCNC.py? The documentation is sketchy on this.
Last edit: 15 Mar 2016 12:23 by comjon.
- comjon
15 Mar 2016 16:52 #71686
by comjon
I bailed on NINJA-IDE for now. Eclipse is easier to use and once I got the PyDev add-ins, everything fell into place.
Thanks for the reply Norbert. You can read my other posts to learn what I am trying to accomplish on a Sherline / /LinuxCNC / MTConnect project.
Time to create page: 0.101 seconds
