Display of Run Time
09 Mar 2019 08:19 #128136
by pl7i92
Display of Run Time was created by pl7i92
Here is a Code to be enterd to display the Runtime
in the panel XML
in the Postgui HAL
in the panel XML
<hbox>
<label>
<text>"Cycle Time"</text>
<font>("Helvetica",14)</font>
</label>
<u32>
<halpin>"time-hours"</halpin>
<format>"2d"</format>
</u32>
<label>
<text>":"</text>
</label>
<u32>
<halpin>"time-minutes"</halpin>
</u32>
<label>
<text>":"</text>
</label>
<u32>
<halpin>"time-seconds"</halpin>
</u32>
</hbox>
in the Postgui HAL
loadrt time
addf time.0 servo-thread
net prog-running not.1.in <= halui.program.is-idle
net cycle-timer time.0.start <= not.1.out
net cycle-seconds pyvcp.time-seconds <= time.0.seconds
net cycle-minutes pyvcp.time-minutes <= time.0.minutes
net cycle-hours pyvcp.time-hours <= time.0.hours
The following user(s) said Thank You: chimeno
- Thank you received: 5945
10 Mar 2019 00:29 #128189
Replied by tommylight on topic Display of Run Time
I will test this tomorrow and report back.
Thank you.
Thank you.
10 Mar 2019 08:24 #128211
by pl7i92
Replied by pl7i92 on topic Display of Run Time
you are welcome to report back it is working here in Education class room
10 Mar 2019 17:17 #128250
Loadrt not
addf not.1 servo-thread
for it to work.
Thank you.
It works, but there have to be added:
loadrt time addf time.0 servo-thread ## net prog-running not.1.in <= halui.program.is-idle net cycle-timer time.0.start <= not.1.out net cycle-seconds pyvcp.time-seconds <= time.0.seconds net cycle-minutes pyvcp.time-minutes <= time.0.minutes net cycle-hours pyvcp.time-hours <= time.0.hours
Loadrt not
for it to work.
Thank you.
11 Mar 2019 07:18 #128298
by pl7i92
Thank you i missed that as i coped from a real machine setup
Time to create page: 0.395 seconds
