How to save/load from memory some value
04 Apr 2019 15:19 #130292
by aleksamc
How to save/load from memory some value was created by aleksamc
Hello all.
In PyVCP panel I want to use value Tool Diameter, that I want to change with help of spinbox.
In spinbox parameters I have <initval>, that is constant.
But tool diameter should be change one time per month only. Can I load this value to some memory after closing linuxcnc and after each start read this value?
04 Apr 2019 16:25 #130295
Replied by andypugh on topic How to save/load from memory some value
Doesn't tool diameter "belong" in the tool table?
(And that is automatically saved and loaded)
04 Apr 2019 20:40 #130308
by aleksamc
Replied by aleksamc on topic How to save/load from memory some value
Sorry for my nuby question, but...
Is it possible to connect pyVCP spinbox to variable #5410 (Tool diameter)?
At start up it should read value of the tool-1, for example, and after turning off - save it to *.var file.
04 Apr 2019 20:47 #130310
Yes, it is probably possible. (though you would have to use something other than #5410, as that is read-only).
What are you trying to do? Why would you not write the new diameter to the tool table instead?
(use a spinbox with a handler that sends an M10 command on MDI)
Time to create page: 0.211 seconds
