how to display a parameter in pyVCP
- jslindsay51
20 Dec 2022 07:17 #259940
by jslindsay51
how to display a parameter in pyVCP was created by jslindsay51
how can I read a parameter set via G code. Example reading the probe position to display on the screen.
I set it to #1000 during the tool length calibration routine, but can't seem to read it for display
John Lindsay
John Lindsay
20 Dec 2022 10:35 #259946
by roland
Replied by roland on topic how to display a parameter in pyVCP
1. in G-Code:
2. in xml file:
3. in the HAL file:
M68 E3 Q#1000
2. in xml file:
<number>
<halpin>"diff-t"</halpin>
<font>;("Helvetica",12)</font>
<format>"+4.3f"</format>
</number>
3. in the HAL file:
net diff-t pyvcp.diff-t motion.analog-out-03
- jslindsay51
20 Dec 2022 14:28 #259957
by jslindsay51
Replied by jslindsay51 on topic how to display a parameter in pyVCP
I'm trying to do exactly that except
net diff-t pyvcp.diff-t comp.0.in1 motion.analog-out-03
I hope that the introduction of the compare input doesn't mess it up.
I'll try to separate them
Thanks a bunch
Thanks a bunch
- jslindsay51
20 Dec 2022 22:04 #259981
by jslindsay51
now I feel really foolish I finally noticed none of my formatting changes were showing up in addition to the described problem. I discovered I was calling the wrong directory for the file back in the INI file. changing it to the correct one solved the problem.
Thanks for the suggestions.
SOLVED!
SOLVED!
Time to create page: 0.073 seconds
