How to connect f-error to pyvcp
- Artur_1617
- Topic Author
- Thank you received: 4
09 Jan 2023 07:47 #261337
by Artur_1617
How to connect f-error to pyvcp was created by Artur_1617
I have problem showing f-error in pyvcp.
Now I make xml file with f-error and this showing correctly but dont change anything if moving axis.
In xml halpin one pin is named x-f-error
In custom.postgui.hal try to connect it with net joint.0.f-error => x-f-error but dont working ( joint.0.f-error exist and I can watching him in halmeter)
I miss something else for work..
Think I must to write something in hall Halui..
10 Jan 2023 02:04 #261404
Replied by cmorley on topic How to connect f-error to pyvcp
please post your confuration files.
- Artur_1617
- Topic Author
10 Jan 2023 18:43 #261477
by Artur_1617
Replied by Artur_1617 on topic How to connect f-error to pyvcp
- Artur_1617
- Topic Author
13 Jan 2023 06:57 #261778
by Artur_1617
14 Jan 2023 02:25 #261849
by MaHa
Replied by MaHa on topic How to connect f-error to pyvcp
I had a few minutes time, to look at this.
in postgui hal:
in xml use e for format
in postgui hal:
net x-err joint.0.f-error pyvcp.x-error
<number>
<format>" 4.6e"</format>
<halpin>"x-error"</halpin>
</number>
The following user(s) said Thank You: tommylight, Artur_1617
- Artur_1617
- Topic Author
19 Jan 2023 07:42 #262383
by Artur_1617
Working but dont show correctly.
When in halmeter show for example 0.003000 in pyvcp show 1.000000-0e
19 Jan 2023 07:55 #262384
by phillc54
Replied by phillc54 on topic How to connect f-error to pyvcp
Try 4.6f for the format.
Time to create page: 1.559 seconds
