Re:pyVCP Online Documents
10 Apr 2009 04:56 #58 by pleezwrite
I have created a pyvcp with a led which should become green when machine reaches the X reference point.
The HALpins are as follows:
- LED: pyvcp.xref
- X ref switch: parport.0.pin-10-in
When I try to modify the custom_postgui halfile the software would not start anymore. I must have made mistakes when connecting the two halpins. How do you do it?
Regards,
Adam
Uses EMC for: 3 axis mill, 2 axis CNC heater
Company profile: recumbent bicycle manufacturer
10 Apr 2009 11:04 - 10 Apr 2009 11:15 #59 by BigJohnT
Replied by BigJohnT on topic Re:Led
I would assume you made some spelling error. It would help if you posted what you added.
Even though this board has little traffic I went ahead and split your question into a new topic just to see if the button worked...
Last edit: 10 Apr 2009 11:15 by BigJohnT.
12 Apr 2009 11:20 #66 by pleezwrite
Replied by pleezwrite on topic Re:Led
Hi John,
As for the custom_postgui.hal I added the following line which does not seem to work well:
net parport.0.pin-10-in => pyvcp.x_ref_led
Regards,
Adam
12 Apr 2009 14:48 #69 by BigJohnT
Ok, what is the code in your .xml file that you used to make the led?
Here is an example that would match your halpin:
<led>
<halpin>"x_ref_led"</halpin>
<size>50</size>
<on_color>"green"</on_color>
<off_color>"red"</off_color>
</led>
If you comment out the net line with # does the led show up? If not then we need to back up to the code that creates the led....
12 Apr 2009 15:16 #70 by alex_joni
Replied by alex_joni on topic Re:Led
That's almost correct, but you're missing the signal name.
The syntax for net is:
net signalname pin1 [pin2, ...]
So you'll have to use:
net pyvcp-led-link parport.0.pin-10-in => pyvcp.x_ref_led
Regards,
Alex
14 Apr 2009 07:22 #81 by pleezwrite
John and Alex,
I think this is exactly what I did but I copied below the XML and HAL files again that I used.
John, when I add the # symbol the led still shows up on the screen and EMC starts. when I delete the symbol EMC would not start anymore and comes up with that usual long error massage with some kernel information at the end.
Panel.xml:
<led>
<halpin>"xref"</halpin>
<size>50</size>
</led>
Custom_postgui.hal:
net X_reference_led pyvcp.xref <= parport.0.pin-10-in
Regards,
Adam
14 Apr 2009 07:27 #82 by alex_joni
Can you use an online pasting facility (like pastebin.ca/) to put that information there? (and give us the resulting link).
The important part is in there ;)
Regards,
Alex
14 Apr 2009 07:40 #83 by pleezwrite
Here it is, hope its readable.
Adam
14 Apr 2009 07:42 #84 by pleezwrite
now?
File Name: error.txt
File Size:40 KB
14 Apr 2009 08:15 #86 by alex_joni
The error is this:
custom_postgui.hal:14: pin 'parport.0.pin-10-in' was already linked
That means you probably connected the pin 10 for something else using stepconf.
If you're sure you're not using, just put an "unlinkp parport.0.pin-10-in" before you do the 'net' to connect the parport pin to the pyvcp pin.
Regards,
Alex
Time to create page: 0.277 seconds
