Conceptual question about stepgen axis control
23 May 2011 20:45 #10013
by thebuc
Conceptual question about stepgen axis control was created by thebuc
Hey guys,
I've been trying to look deeper into how all of this stuff works and I have a question.
Here is the HAL code that controls one of my axes: (i excluded all the things like loadrt and threads)
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 45000
setp stepgen.0.dirsetup 26000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
I think i understand how it takes an input position command from the user and then creates a stepgen signal with the right number of steps to get exactly to that position while staying below the max accel and velocity.
But im wonding how does it take the feedrate input from the user?
Say if i did the MDI command:
x1 F5
I think i understand how stepgen can make the machine go to x=1, since each pulse is 1 microstep, but how does it do it at a feedrate of 5? I don't see any input pins for feedrate/velocity.
I know it could adjust velocity by adjusting the frequency of the pulses but where is my input feedrate used?
-Greg
x1 F5
-Greg
23 May 2011 20:51 #10014
Replied by andypugh on topic Re:Conceptual question about stepgen axis control
EMC2 sends a new position command every millisecond (typically, whatever the servo thread rate is). It is the rate of change of that value which controls the feed rate.
23 May 2011 21:07 #10015
by BigJohnT
Replied by BigJohnT on topic Re:Conceptual question about stepgen axis control
This is just the tip of the iceberg... the trajectory planner does the magic from what the interpreter sends it "I think"
From the user end this is a good read.
www.linuxcnc.org/docview/html/common_User_Concepts.html
This is the Developers Manual
www.linuxcnc.org/docs/EMC2_Developer_Manual.pdf
23 May 2011 21:13 #10016
by thebuc
Replied by thebuc on topic Re:Conceptual question about stepgen axis control
Hmm okay.
So maybe it goes like this: ? (continuing with previous example)
if i say
x1 F5
EMC will automatically divide 1inch by 5in/min to get some total travel time so 0.2min
and then it will do 0.2min/1milisec = 12000 position commands
and then you could do 1inch/12000 commands and get some really small distance per command? and i guess this would be at the feedrate.
so on every new command it would say go that much further and keep the feedrate constant. And this would be coming in from "axis.0.motor-pos-cmd"
i guess the first few commands and the last few are a bit odd though because of max acceleration. And i guess a millisecond is a small enough time frame that it can never accelerate past the feedrate? Hmm.
Is that sort of how it is calculated?
if i say
x1 F5
23 May 2011 21:42 #10017
by BigJohnT
If you don't have the naive cam detector enabled (in the link) then EMC calculates the acceleration to the feed rate and also slows down in time to stop at the end point, so it is a very complex calculation.
This is a good link to Anders Wallin's page that explains the trajectory planner.
www.anderswallin.net/tag/emc2/
Time to create page: 0.562 seconds
