HAL net command question
03 Jul 2011 17:53 #11105
by kostas
HAL net command question was created by kostas
I made some experiments for a custom component that I make and saw that when I create a new signal and connect a pin to it, the signal defaults to a value of 0.
I thought that the signal would take the pin's value.
Is this correct or am I missing something?
03 Jul 2011 18:42 #11107
Replied by andypugh on topic Re:HAL net command question
The signal will only take the value of the pin if the pin is an output. And, also, if the component is running (ie, attached to a thread, with the thread started)
03 Jul 2011 18:51 #11108
by kostas
Replied by kostas on topic Re:HAL net command question
Both signals I connect are IO. I guess taking the value of the pin doesn't apply to this type?
What I try to do is make a component that will change a pin based on it's previous value and adding a value from some other component pin, which will change.
My purpose is to be able to change the pid values with the help of some external rotary encoders. I want to be able every time to start with the predefined pid values though and not from zero.
03 Jul 2011 20:05 #11113
Create a parameter called (for example) "init-value" then you can use setp in the HAL file to give it a starting value.
From then on the code can use that as a variable, as the setp command is only run once when the hal file is loaded.
03 Jul 2011 20:10 #11115
by kostas
Yep! That's what I did already. I think I managed to get it working now. It would be much easier and simple if the values were loaded from the pin though.
Doing some initial tests now. I'm in a good path already.
03 Jul 2011 23:07 #11116
kostas wrote:
If you think it through carefully, I think you would find that that could lead to inconsistency. How do you decide which value to use?It would be much easier and simple if the values were loaded from the pin though.
04 Jul 2011 05:48 #11120
by kostas
Yes, I know. I would take the value of the first pin connected on the net, but this would probably lead to some other problems.
Time to create page: 0.284 seconds
