File to Edit to add backplot tabs
20 Jul 2011 12:22 #11685
by BigJohnT
Replied by BigJohnT on topic Re:File to Edit to add backplot tabs
I'm confused, what was the question?
20 Jul 2011 12:41 #11686
by piasdom
Replied by piasdom on topic Re:File to Edit to add backplot tabs
when i do slot, it gives the error but loads in the bottom panel.
so i can see what it would do. it has my parameters that
i entered under the tab before finalizing. all the file
paths are correct. i get error msg -
near line 3 of /home/mill/emc2/configs/Axis/auto.ngc
nested comment found.
auto.ngc is the auto file that starts with ngcgui.
i looked thur it and actually change to remove errors,
but soon i have no file but i reloaded and auto was back
to normal.
to normal.
20 Jul 2011 13:14 #11687
by BigJohnT
Attach the auto.ngc file without changing anything so I can look at it.
20 Jul 2011 13:16 #11688
by piasdom
20 Jul 2011 13:31 #11690
by BigJohnT
The problem is your path to the g code file /home/mill/Gcode(Linux)/, don't use anything but letters, numbers, and the under score or dash in your directory name.
20 Jul 2011 13:54 #11691
by piasdom
THANKS John !
can't wait for 2.5
can't wait for 2.5
