pass a tool number back to currentoolnumber
28 Jul 2011 17:32 #11964
by cncbasher
pass a tool number back to currentoolnumber was created by cncbasher
with great help and assistance from Arceye , i now can proceed fitting my toolchanger , and it seems to be working , excepting a small hickup or future emc enhancement ! , as follows :
how can i pass a toolnumber back to currentoolnumber from a comp
i have a toolnumber derived from reading greycode and rather than manualy inputing the number using mdi with M6Tx etc , i'd like this read in to currenttoolnumber on startup , ?
and shown on a pyvcp panel etc .
any ideas on how to return the value of the tool in real time
28 Jul 2011 18:06 #11966
by BigJohnT
Replied by BigJohnT on topic Re:pass a tool number back to currentoolnumber
I use a combination of classic ladder and hal to run my tool changer.
gnipsel.com/shop/hardinge/hardinge.xhtml
I read in the tool number requested and when the proper tool comes into view I lock the turret.
AFAIK tool changers don't need anything real time... except for some of the real modern real fast ones.
01 Aug 2011 09:17 #12075
by ArcEye
Hi
Glad to hear the tool changer component is working!!!
I take it the component is warning that no tool number is set after you are homed and that you could just enter M6Tn in the MDI to update it?
The problem with trying to do it internally is that currenttoolnumber is set by iocontrol after it receives a toolchanged signal.
iocontrol just sets currenttoolnumber to the requested M6Tn toolnumber on being notified that change occurred.
For that reason the easiest way to update Axis is to M6Tn to the tool you are already on and the component will not move the ATC because it recognises that currenttoolnumber is not set, so this is an initialising command.
I don't know why Axis does not store the last used tool number and re-instate it at start up time, it could be because of the scenario in para 3.
At present the pin position I left visible for debugging, does not show a position until a tool change is requested.
I could change that and have it read position if currenttoolnumber is empty but I will have to do some thinking about how the data can be used.
It cannot just write to the iocontrol.0.tool-number because that is an output from iocontrol.
You could read it and automatically generate a M6Tn command outside the component, but that is just the same as doing it from the MDI really.
I'll have a ponder on it.
Replied by ArcEye on topic Re:pass a tool number back to currentoolnumber
with great help and assistance from ArcEye , i now can proceed fitting my toolchanger , and it seems to be working
Hi
03 Aug 2011 12:20 #12153
by ArcEye
Hi
I have amended iocontrol to create an extra pin to receive the start-up tool number from a further amended toolchanger component.
When linked in your .hal file the toolchanger will read the current position at start up, send it to iocontrol which will initiate a toolchange to that number.
Because the tool changer component knows that this is initialisation, no movement takes place and the current tool is updated in emc and the Axis display.
Files sent to you via email for testing
