Connect comp param to GUI
03 Oct 2011 16:31 #13628
by fma
Connect comp param to GUI was created by fma
I'm trying to connect some comp params (pid Pgain,Igain and Dgain) to my GUI (pyvcp), but it does not work. I get the following error:
'Signal temp_pid_P can not add OUT pin 'pyvcp.temperature_pid_P', it already has I/O pin 'pid.0.Pgain'.
In file temperature.hal:
net temp_pid_P pid.0.Pgain
In file 'temperature_gui.hl' file:
net temp_pid_P pyvcp.temperature_pid_P
Is there a way to do that?
Thanks,
Thanks,
03 Oct 2011 17:24 #13629
by ArcEye
Replied by ArcEye on topic Re:Connect comp param to GUI
Hi
Those pins are shown as I/O
The below works on my simulation
net temp-pid-P <= pid.0.Pgain => pyvcp.temperature-pid-P
I changed to dashes rather than underscores, comp converts underscores in pin names to dashes when compiling a component I seem to recall, sometimes using a name with 2 or more underscores seemed to produce an error, so I stopped using them when naming my own pins and signals.
03 Oct 2011 17:39 #13630
Replied by andypugh on topic Re:Connect comp param to GUI
ArcEye wrote:
Is your pyvcp an output or an input?
I get the same error connecting a simple output pin (from constant) to Pgain.
03 Oct 2011 17:49 #13631
by BigJohnT
Replied by BigJohnT on topic Re:Connect comp param to GUI
I get the same error trying to connect a spin box pin to the I/O
03 Oct 2011 18:21 #13632
You can only link I/O type pins to inputs, or other I/O pins (as only one pin in a net is allowed to be a writer)
As far as I can see there is no good reason for the gain pins to be I/O.
You _might_ find that the machine->calibration screen does what you want, have you tried that?
There are a number of inelegant solutions:
1) Change the pin type in /usr/share/pyshared/pyvcp_widgets.py
Possibly better to copy and paste the spinbox control name into a widget with a new name.
The magic value is on line 800 (if you are using a spinbox), change HAL_OUT to HAL_IO
This is a runtime-interpreted file, so there should be no need to recompile anything.
2) Edit and recompile pid.c You will need the file to do this (you could pick up just that one file from git.linuxcnc.org, it's in src/hal/components
You can recompile and install using comp, without needing to reinstall all of EMC2.
In some ways this it the tidiest option.
3) create a very simple HAL module with an IN pin and an IO pin, and a function that make out = in.
Again, that would need to be compiled with comp.
03 Oct 2011 21:17 #13633
by fma
Replied by fma on topic Re:Connect comp param to GUI
Solution 3) seems to me to be the best. I'll try that.
Thanks!
Thanks!
03 Oct 2011 21:39 #13634
Now we have spotted this problem we might change those pins to inputs in the next EMC2 release. Nobody I have talked to so far thinks that makes any sense.
03 Oct 2011 21:54 #13635
by fma
I wrote the comp as suggested, and it works fine. Maybe such comp could be added to EMC2 core?
Another solution could be to allow a widget to be an i/o, so it can be connected to such i/o param? This will allow the widget to be refreshed/initialize from the param, as we often do in GUI programming...
Time to create page: 0.267 seconds
