axis.n.in-position does not work in mdi/auto
31 Oct 2011 15:16 #14469
Replied by andypugh on topic Re:axis.n.in-position does not work in mdi/auto
strykerg wrote:
Nothing with floating point can go in the base thread. This needs to go in the servo thread. (the velocity pin will only change in the servo thread anyway).
Make sure you add the "near" function earlier than the stepgen functions, so that the drive turns back on before the pulses start.
addf near.0 base-thread
(sice i need this to be fast i would add it to the base thread...)
31 Oct 2011 16:31 #14470
by strykerg
Replied by strykerg on topic Re:axis.n.in-position does not work in mdi/auto
oh ok i get it. so the actual movement is calculated in the servo thread anyway. so the pin's change should be as fast as the first step.o
in about 2-3 hours i will be at home and try it out. i will let you know.
thanks four your great help for now.
31 Oct 2011 21:11 #14474
by Rick G
Replied by Rick G on topic Re:axis.n.in-position does not work in mdi/auto
The near works for me in a similar set up.
The man page Andy pointed to has the info on setting it up.
You can set one input to 0 and use that to compare to the hal pin.
Rick G
Rick G
31 Oct 2011 21:23 #14475
by strykerg
hi guys,
thanks both for all your help.
everything worked as it should and i had no problems at all.
i am finally starting to understand how things work with hal and I am seeing how powerful and flexible emc2 is.
thanks again for all your help
best regards
best regards
01 Nov 2011 10:22 #14479
by Rick G
Great, glad to hear you are up and running.
Rick G
Rick G
Time to create page: 0.173 seconds
