Saving parameters after shut down
09 Jan 2020 20:25 - 24 Dec 2020 13:28 #154481
by jurod
Replied by jurod on topic Saving parameters after shut down
Hi
I have problem with paramsaver syntax. "safe tool change" . I would like the syntax and links to hal components. I need at the toolchange, write new tool to paramsavers. I would like to look into yours hal and ini.
I don't know how to use M68, with motion.analog-out-xx.
My hal:
# _DO NOT_ include your HAL commands here.
# Put custom HAL commands in custom_postgui.hal
# The commands in this file are run after the GUI loads
# **** Setup of spindle speed display using pyvcp -START ****
net spindle-vel-cmd-rpm-abs => pyvcp.spindle-speed
#prisavky s materialom
net appc halui.mdi-command-10 pyvcp.appc
net ap halui.mdi-command-12 pyvcp.ap
net am halui.mdi-command-13 pyvcp.am
net nul halui.mdi-command-14 pyvcp.nul
########################## FILE SAVER ###################################
loadusr -W paramsaver f=3 s=1 b=0 filename=memory_pins onstart=1 onexit=1
net material_in pyvcp.mat => paramsaver.invalueF-000
net material_out pyvcp.spinbox.0.param_pin <= paramsaver.outvalueF-000
net podlozka_in pyvcp.pris => paramsaver.invalueF-001
net podlozka_out pyvcp.spinbox.1.param_pin <= paramsaver.outvalueF-001
############################### Memory tool #########################################
net tool_number_in iocontrol.0.tool-number => paramsaver.invalueS-000
net tool_number_out ?????????????????? <= paramsaver.outvalueS-000
net writetrigger motion.digital-out-03 paramsaver.writetrigger
net readtrigger motion.digital-out-04 paramsaver.readtrigger
########################## FILE SAVER END ###################################
My hal:
Last edit: 24 Dec 2020 13:28 by jurod.
12 Jan 2020 09:13 #154666
by jurod
Please help me. Some example, link, reference, anythink.
14 Jan 2020 17:09 #154833
Replied by andypugh on topic Saving parameters after shut down
What problem do you have?
ie: What do you do, what happens, how is that different from what you expected to happen?
16 Jan 2020 06:45 - 24 Dec 2020 13:29 #154996
by jurod
I have problem with paramsaver, his syntax. Not worked.
But now i have progress with the paramsaver.
This works:
In custom hal:
loadusr -W paramsaver f=3 s=0 b=0 filename=memory_pins onstart=1 onexit=0 (onexit=0 it has to be)
net tool_number_in motion.analog-out-04 => paramsaver.invalueF-002
net tool_number_out <= paramsaver.outvalueF-002
in INI:
MDI_COMMAND=M120 M61 Q[#<_hal[tool_number_out]>]
REMAP=G88.1 modalgroup=1 ngc=g881 (The program that is called on the last calibrated axis)
The program:
o<g881> sub
M61 q#<_hal[tool_number_out]>
o<g881> endsub [1]
m2
Thanks.
This works:
In custom hal:
in INI:
The program:
o<g881> sub
o<g881> endsub [1]
m2
Thanks.
Last edit: 24 Dec 2020 13:29 by jurod.
25 Dec 2020 11:32 - 25 Dec 2020 11:50 #193170
by jurod
Hi
Problem with "paramsaver" in version 2.8.0
For version 2.7.14 in the terminal compile command "halcompile --install --userspace /home/hcnc/linuxcnc/paramsaver.c" looks like this:
Extract from the terminal:
Works OK on my config machine,
but for version 2.8.0 in the terminal compile command "halcompile --install --userspace /home/hcnc/linuxcnc/paramsaver.c" looks like this:
Extract from the terminal:this no works. The paramsaver component was not created.
From the terminal LinuxCNC Errors:
I have already installed "build-essential" and "linuxcnc-dev"
Where is the problem? Please help.
root@H61M-C:/home/hcnc# halcompile --install --userspace /home/hcnc/linuxcnc/paramsaver.c
gcc -Os -g -I. -I/usr/realtime-3.4-9-rtai-686-pae/include -I. -I/usr/realtime-3.4-9-rtai-686-pae/include -I/usr/include/i386-linux-gnu -U_FORTIFY_SOURCE -D_FORTIFY_SOURCE=0 -fno-math-errno -funsafe-math-optimizations -fno-rounding-math -fno-signaling-nans -fcx-limited-range -mhard-float -DRTAI=3 -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime -D__MODULE__ -I/usr/include/linuxcnc -Wframe-larger-than=2560 -URTAPI -U__MODULE__ -DULAPI -Os -o paramsaver /tmp/tmpgNP5a4/paramsaver.c -Wl,-rpath,/lib -L/lib -llinuxcnchal
root@E8400:/home/hcnc# halcompile --compile --userspace /home/hcnc/linuxcnc/paramsaver.c
gcc -I/usr/include -I/usr/include/linuxcnc -URTAPI -U__MODULE__ -DULAPI -Os -o paramsaver /tmp/tmpAzSwbK/paramsaver.c -Wl,-rpath,/lib -L/lib -llinuxcnchal
File "/usr/bin/paramsaver", line 3
SyntaxError: invalid syntax
pyvcp_options.hal:13: waitpid failed paramsaver paramsaver
pyvcp_options.hal:13: paramsaver exited without becoming ready
3626
3679
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtime
Last edit: 25 Dec 2020 11:50 by jurod.
- Thank you received: 5938
25 Dec 2020 15:21 #193181
Replied by tommylight on topic Saving parameters after shut down
Well for one you are using ROOT on a Linux box, and that is never a good idea, from security standpoint and from the issues that arise with software that is made to run as a normal user with limited privileges, access to files and folders, etc.Where is the problem? Please help.
25 Dec 2020 21:24 - 25 Dec 2020 21:43 #193194
by phillc54
The second command only compiles the component it does not install it. You need to use the first command to install the component.
Edit:
linuxcnc.org/docs/html/hal/comp.html#_compiling
Replied by phillc54 on topic Saving parameters after shut down
Works OK on my config machinehalcompile --install --userspace /home/hcnc/linuxcnc/paramsaver.c
this no works. The paramsaver component was not created.halcompile --compile --userspace /home/hcnc/linuxcnc/paramsaver.c
Edit:
Last edit: 25 Dec 2020 21:43 by phillc54.
25 Dec 2020 21:48 - 25 Dec 2020 21:50 #193195
by jurod
BOOM!!!!! I'm stupid. I didn't notice the difference written --install and --compile. Thanks.
It's already working.
Last edit: 25 Dec 2020 21:50 by jurod.
30 Dec 2020 00:12 #193471
I have been keeping this in my inbox to get back to.
Glad that I didn't need to.
But I will point out that you should probably have saved the file as "paramsaver.comp" and used halcompile --install paramsaver.comp
You don't say if you pre-processed to a C file, but I assume so. There is no need.
The .comp file has the keywords to declare that it is userspace.
04 May 2021 07:38 - 04 May 2021 16:38 #207799
by jurod
Hi, I have a problem again. After a clean installation 2.8.1 i can't install paramsaver correctly.
From terminal>Paramsaver is not in the machine configuration.
I did the installation:
BUSTER
sudo apt-get install build-essential
linuxcnc-uspace-dev
linuxcnc-uspace-dbgsym
EDIT: solved
From terminal>
hcnc@DH61SA:~$ sudo halcompile --install --userspace /home/hcnc/linuxcnc/paramsaver.c
gcc -I/usr/include -I/usr/include/linuxcnc -URTAPI -U__MODULE__ -DULAPI -Os -o paramsaver /tmp/tmpbF1yoR/paramsaver.c -Wl,-rpath,/lib -L/lib -llinuxcnchal
BUSTER
linuxcnc-uspace-dev
EDIT: solved
Last edit: 04 May 2021 16:38 by jurod.
Time to create page: 0.116 seconds
