XHC-HB04 wireless MPG pendant HAL module
03 Oct 2013 03:20 #39492
by rmagnus
Replied by rmagnus on topic XHC-HB04 wireless MPG pendant HAL module
Hello .\
I pasted the exact MDI_COMMAND you kindly suggested, without knowing what to do with commands 0 to 5 so I left the ... after the = . Is that OK?
The goto zero button now works connected to the MDI 9
now the problem is that my pendant has no touch x , y and z buttons, instead it has a =0 button that is supposed to touch to zero the selected axis with the dial.
so the MDI 6, 7 and 8 commands dont work, if I try to uncomment the next lines it crashes....
#net x0 halui.mdi-command-06 xhc-hb04.button-x0
#net y0 halui.mdi-command-07 xhc-hb04.button-y0
#net z0 halui.mdi-command-08 xhc-hb04.button-z0
I have no idea how to make it work.
Thank you for your help!
Rodolfo
Rodolfo
03 Oct 2013 03:39 #39493
by rmagnus
I was reading on this same thread that Tommy managed to use his =0 button but then ran into problems when he said
"But there is still a BIG issue with unwanted switching to joint mode when calling subroutine trough MDI_COMMAND"
And he with Andypough tried to fix it but I don´t know how it ended.
So I don´t know what to do next to make my =0 button work.
Thanks again
Thanks again
03 Oct 2013 18:50 #39503
What sort of machine are you using? Unless you have a non-trivial kinematics loaded (like for a robot, or possibly a dual motor gantry) then you won't see that issue.
Replied by andypugh on topic XHC-HB04 wireless MPG pendant HAL module
The following user(s) said Thank You: rmagnus
04 Oct 2013 02:54 #39513
by f1oat
For this pendant, use xhc-hb04-layout2.ini layout definition file
If you modify your xhc-hb04.hal file as below, it should work:
Sorry, I have no access to my machine to verify the syntax. Hope there are not too much mistakes !
Frederic.
Replied by f1oat on topic XHC-HB04 wireless MPG pendant HAL module
You will need to build a HAL config file with AND component to handle the axis selection switch.I was reading on this same thread that Tommy managed to use his =0 button but then ran into problems when he said
Thanks again
loadusr -W xhc-hb04 -I xhc-hb04-layout2.ini -H
loadrt and2 count=3
# X=0, Y=0, Z=0
net zero xhc-hb04.button-zero => and2.0.in0 and2.1.in0 and2.2.in0
net jog-x and2.0.in1
net jog-y and2.1.in1
net jog-z and2.2.in1
net x0 halui.mdi-command-06 <= and2.0.out
net y0 halui.mdi-command-07 <= and2.1.out
net z0 halui.mdi-command-08 <= and2.2.out
net origin halui.mdi-command-09 xhc-hb04.button-goto-zero
Frederic.
04 Oct 2013 03:20 #39515
by rmagnus
My machine is a probotix comet so yes it has 2 motors for the y axis. Should I do something different?
Thank you!
Thank you!
04 Oct 2013 03:23 #39516
by rmagnus
I will try it and report back thanks!
So for the Probotix comet with 2 motors for the gantry what should I be aware of ? I don't want to damage it
Thank you
Thank you
04 Oct 2013 04:08 #39517
Are you using trivkins or gantrykins?
Does the machine start up in Joint mode?
ISo for the Probotix comet with 2 motors for the gantry what should I be aware of ? I don't want to damage it
04 Oct 2013 04:43 #39519
by rmagnus
I have no idea! Probotix ships the machine ready to run so this is the first time I hear about that
Where do I look for. Excuse my ignorance
04 Oct 2013 19:06 #39537
When you start the machine, are the axes referred to as 0,1,2,3 and do you then need to switch to World Mode after homing?
If no then you don't have a Joint Mode to worry about.
06 Oct 2013 09:16 #39592
by rmagnus
Hello Frederic
Thank you for the help.
I had problem implementing.
I did what you suggest but got this error:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
Unrecognized line skipped: POC FMS LEN DIAM COMMENT
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/and2.ko': -1 File exists
xhc-hb04.hal:3: exit value: 1
xhc-hb04.hal:3: insmod failed, returned -1
See the output of 'dmesg' for more information.
2375
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
And if I comment the lone loadrt and2 count=3 I get this error.....
xhc-hb04.hal:52: Pin 'and2.0.in0' was already linked to signal 'switches-y1'
2076
Please advice!
Thank you
Rodolfo
2375
2076
Please advice!
Thank you
Rodolfo
Time to create page: 0.126 seconds
