huanyang vfd & linuxcnc 2.7
27 May 2015 13:01 #59100
by vre
huanyang vfd & linuxcnc 2.7 was created by vre
I have linuxcnc 2.7 and iam trying to compile this
github.com/bebro/linuxcnc-huanyang-vfd
but it does not compile.. comp command does not exist in 2.7 version .
Any help how to compile and install this huanyang vfd plugin ?
27 May 2015 13:05 #59101
by ArcEye
Replied by ArcEye on topic huanyang vfd & linuxcnc 2.7
comp was renamed halcompile, remainder of switches etc are the same.
Name clashed with other apps to do with comparison and was causing confusion with some users.
The following user(s) said Thank You: vre
28 May 2015 00:09 #59115
by vre
Replied by vre on topic huanyang vfd & linuxcnc 2.7
i have installed this github.com/bebro/linuxcnc-huanyang-vfd/tree/linuxcnc
but linuxcnc can not start.
Iam using a usb to rs485 adapter recognized as /dev/ttyUSB0
28 May 2015 06:15 #59135
If you try to start linuxcnc from the command line (command "linuxcnc") then there should be details of the error that is preventing the start. (probably buried in other stuff).
Replied by andypugh on topic huanyang vfd & linuxcnc 2.7
28 May 2015 07:03 #59139
by alan_3301
Replied by alan_3301 on topic huanyang vfd & linuxcnc 2.7
the binary is there, you don't need to compile if you don't want to
post the errors you are getting. I have a bunch of experience with this, just need to remember all the problems I had getting it going.
28 May 2015 17:14 - 28 May 2015 17:16 #59145
by vre
I have compiled fine but binary seems that can not connect..
Iam using this adapter www.ebay.com/itm/New-USB-to-RS485-USB-48...Mac-OS-/381097954687
I will buy now this adapter www.ebay.com/itm/RS-232-New-RS232-to-RS-...verter-/141516794700
perhaps the problem is the adapter or the wire lenght and termination i connected it without 120 ohm resistors
Last edit: 28 May 2015 17:16 by vre.
28 May 2015 17:17 #59146
by alan_3301
have you set up your vfd correctly?
PD001 = 2 (run commands to comm port)
PD002 = 2 (operating freq to comm port)
PD163 = 1 (slave address 1)
PD164 = 1 (baud rate to 9600 b/s)
PD165 = 3 (8N1 for RTU mode)
28 May 2015 17:22 #59147
by alan_3301
you can pick what you want for pd164 and pd165, just make sure they match what is specified in custom.hal
28 May 2015 17:25 #59148
by alan_3301
It is helpful to setup a loopback, and using a terminal program, make sure the rs485 is working.
I had to verify my stuff on a scope to make sure which wire was + and what was -. also I had to leave off the 120 ohm resistors, the waveform became unreadable with them installed.
once that side of everything is working, it's just a matter of making sure all the vfd settings match what the parameters for custom.hal
you can run hy-vfd in a terminal to see all the command line options.
29 May 2015 01:44 #59161
by vre
I have been set the parameters correctly to the vfd and code
but the output is: RTAPI error can't access shared memory and then segfault.
Time to create page: 0.226 seconds
