halcompile error
05 May 2016 20:52 - 06 May 2016 02:39 #74283
by joekline9
halcompile error was created by joekline9
I can't get halcompile to work for a userpace comp. See error below:
joe@Shermill:~$ sudo halcompile --install --userspace testusr.comp
File "/usr/bin/halcompile", line 1353, in <module>
main()
File "/usr/bin/halcompile", line 1322, in main
process(f, mode, outfile)
File "/usr/bin/halcompile", line 1192, in process
a, b = parse(filename)
File "/usr/bin/halcompile", line 417, in parse
a, b = f.split("\n;;\n", 1)
ValueError: need more than 1 value to unpack
I am on Debian Wheezy and linuxcnc 2.7.4
main()
Last edit: 06 May 2016 02:39 by joekline9.
06 May 2016 18:27 #74313
by joekline9
Well I found the problem. DOS style line endings.
I just had to do Save As in Gedit and choose Unix/Linux not windows Line endings.
It would be nice if Halcompile would just ignore the '/r' but............
Replied by joekline9 on topic halcompile error
- Thank you received: 1369
06 May 2016 19:32 #74315
Replied by Todd Zuercher on topic halcompile error
Be nicer if Microsoft would just use the same endings as every one else
Time to create page: 0.134 seconds
