rs485 huanyang speed control
30 Jun 2018 17:08 #113137
Replied by andypugh on topic rs485 huanyang speed control
Halmeter, Halscope and Halshow are extremely useful tools.
You can add them all to the HAL file too, if you want.
loadusr halmeter -s pin vfd.speed-command
For example will always load a small halmeter showing that pin.
I have a couple on my lathe config that are now irrelevant and annoying. I should remove them.
The following user(s) said Thank You: BrendaEM
30 Jun 2018 18:32 - 30 Jun 2018 18:53 #113140
by BrendaEM
Replied by BrendaEM on topic rs485 huanyang speed control
I rechecked the VFD to make sure it is set to accept commands from the communication port.
I commented out the classic ladder stuff in the .hal. It runs no different, so at some point I guess I can remove it.
The Axis Spindle Override slider also has no authority over the spindle.
Oddly, the Axis Spindle Speed indicator reads from 0 to 3000. Hmm.
Probing HAL Meter signals while adjusting the spindle speed using the + and - ....
1.) The spindle-at-speed remains false.
2.) The spindle-command-rpm and spindle-command-rpm-abs jumps from 1 to 101 then progresses as increase to 3000 and beyond the GUI indicator. Interesting.
3.) The spindle-command-rps and spindle-command-rps-abs jumps from .016666x and progresses as increase. I am assuming that these are a rev per sec.
Looking at the VFD display as the motor is activated, the frequency remains at 110 hz (my chosen minimum) and the RPM at 6600.
I read what you wrote about frequency scaling, and perhaps the frequency needs to be scaled, but before I do that I will need to learn whether the VFD driver is sending frequency requests or RPM, and also look into why others have not had this problem.
Last edit: 30 Jun 2018 18:53 by BrendaEM.
30 Jun 2018 19:00 - 30 Jun 2018 20:33 #113141
by BrendaEM
Eureka!!! I found the problem!!!
Donning safety google, because I am now sitting pretty close to the spindle, I energized the system, and launched LinuxCNC...
While probing the spindle-command-rpm-abs signal, I clicked on the RPM increase until I got over 6600. As soon as I passed it, the motor RPM went up, and the at-speed indicator finally went green. : )
The system was sending correctly scaled RPM commands, but the sent speed was lower than the user-set VFD minimum, so that is what it was giving me. (Apparently, Huanyang air-cooled spindles motors don't like running under 110Hz, the water-cooled ones below 100hz, so I had indeed set those values.)
Editing the custompanel.xml control, changing the 3000 to 24000, fixed the visual widget issue.
The too-many-clicks issue was lessened by editing the .ini [DISPLAY] section, adding:
Ref: forum.linuxcnc.org/21-axis/34056-spindle...nimum-starting-value
Though, the build code would have to be changed in Axis to change the increments, from what I have read, which likely should have been a ini variable.
I've removed all the classic ladder and PWM statements from my .hal.
Thank you all who helped me : )
DEFAULT_SPINDLE_SPEED = 6600
Last edit: 30 Jun 2018 20:33 by BrendaEM.
30 Jun 2018 21:19 #113145
Use MDI and M3 commands to set the spindle speed directly.
Normally the correct spindle speed will be set by the G-code.
M3 S20000
M3 S20000
01 Jul 2018 01:23 - 01 Jul 2018 01:36 #113149
by BrendaEM
I thought my first cut would be manual, but I used NativeCam to cut a pocket in a scrap of plywood.
It made chips!
Thank you again!
It made chips!
Thank you again!
Last edit: 01 Jul 2018 01:36 by BrendaEM.
Time to create page: 0.092 seconds
