LinuxCNC Forum
Toggle Navigation
Remember Me
Log in
Forgot Login?
Sign up
Index
Recent Topics
Search
www.linuxcnc.org
Configuring LinuxCNC
HAL
python component help[SOLVED]
Start
Prev
1
Next
End
1
TurBoss
Offline
Premium Member
Thank you received: 72
03 Aug 2016 06:19
03 Aug 2016 09:24
#78316
by
TurBoss
was created by
TurBoss
Hi
Im writing a python component
it has 8 inputs an 10 outputs
if i set pin 0 to TRUE in halrun it works but no if i set it to FALSE
python component :
dpaste.com/0C772SF
halrun session:
dpaste.com/31ND4Y3
I'm sure is something easy but can't find it
thx!
edit: instad of asing a variable other variable now i copy the value with copy.copy(value)
so problem solved
Last edit: 03 Aug 2016 09:24 by
TurBoss
Please
Log in
or
Create an account
to join the conversation.
Start
Prev
1
Next
End
1
Board Categories
LinuxCNC
- LinuxCNC Announcements
General
- General LinuxCNC Questions
- Installing LinuxCNC
- Documents
- StepConf Wizard
- PnCConf Wizard
- Basic Configuration
- ClassicLadder
- HAL
- HAL Examples
- Advanced Configuration
- EtherCAT
User Interfaces
- AXIS
- Gmoccapy
- Plasmac
- pyVCP
- GladeVCP
- PathPilot
- Other User Interfaces
- QtPyVCP
- Qtvcp
GCode and Part Programs
- G&M Codes
- O Codes (subroutines) and NGCGUI
- - Mill Library
- - Lathe Library
- - Plasma Library
- CAD CAM
- - Post Processors
- - - Fusion 360
- - - MasterCAM
- - - MecSoft
- - NativeCAM
Hardware & Machines
- Computers and OS's
- Driver Boards
- Milling Machines
- CNC Machines
- Turning
- Plasma & Laser
- Pick and Place
- Additive Manufacturing
Other Stuff
- Show Your Stuff
- Forum Questions
- User Exchange
- Off Topic and Test Posts
- - BeagleBone
International LinuxCNC Users
- Français
- Español
- Polski
- Deutsch
- Russian
- Other Languages
HAL
Time to create page: 0.095 seconds
Powered by
Kunena Forum
