halcopile problem / new ubunu 14.04 installation
01 Dec 2016 15:35 - 01 Dec 2016 15:36 #83527
by bkt
Replied by bkt on topic problem with compile custom comp --- library path
so I've try to make debian pakage with userspace rtai option ... with 2 error ... so I cancell all and try to userpace onli ... same 2 error....
the rules file attach
so now cancell for 10° time the linuxcnc-dev folder and re-run usual dance with git..... linuxcnc-dev...
giorgio
rned exit code 2
make: *** [binary-arch] Errore 2
dpkg-buildpackage: Errore: fakeroot debian/rules binary gave error exit status
giorgio
Last edit: 01 Dec 2016 15:36 by bkt.
02 Dec 2016 09:20 #83562
by bkt
I have some problem with ubuntu 14.04 and Lcnc Master .... so I install debian 7 iso .... on new ssd ....
my kins compile fine, my custom comp compile fine .... but my config not start at all .... not find
NOTE: my config came from 1 year of perfect working on ubuntu 10.04 ja9 ....
So I think: ok Lcnc 2.7.8 is not able to recognise joint vs. axes .... so I've upgrade to MASTER ..... surprise, surprise...
mykustom kins compile fine ....
K1MbServer.comp only if cancel row about option singleton at all .....
but When try to run my config obtain these error:
or my config is write in wrong way for new master (probabily yes) .... or there are a problem (I hope I'm in wrong).... any how singleton problem is on MASTER BRANCH ....
Regards
Giorgio
Warning: Spoiler!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.8.0-pre1-2762-g42ff261
Machine configuration directory is '/home/k1/linuxcnc/configs/n'
Machine configuration file is 'n.ini'
INIFILE=/home/k1/linuxcnc/configs/n/n.ini
VERSION=1.0
check_config: Unknown [KINS]KINEMATICS=delta_AAB_inv
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z A
Starting LinuxCNC...
Found file(REL): ./n.hal
Starting DISPLAY program: axis
waiting for s.joints<0>, s.kinematics_type<0>
Running HAL shutdown script
Killing task linuxcncsvr, PID=4784
Debug file information:
/usr/bin/milltask exiting
<commandline>:0: milltask exited without becoming ready
note: MAXV max: 10000.000 units/sec 600000.000 units/min
note: LJOG max: 10000.000 units/sec 600000.000 units/min
note: LJOG default: 2000.000 units/sec 120000.000 units/min
note: AJOG max: 3600.000 units/sec 216000.000 units/min
note: AJOG default: 166.667 units/sec 10000.002 units/min
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
4784
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[ 0.000000] BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000c57df000 (usable)
[ 0.000000] BIOS-e820: 00000000c57df000 - 00000000c57e6000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000c57e6000 - 00000000c6131000 (usable)
[ 0.000000] BIOS-e820: 00000000c6131000 - 00000000c63e1000 (reserved)
[ 0.000000] BIOS-e820: 00000000c63e1000 - 00000000d83f6000 (usable)
[ 0.000000] BIOS-e820: 00000000d83f6000 - 00000000d8460000 (reserved)
[ 0.000000] BIOS-e820: 00000000d8460000 - 00000000d84c6000 (usable)
[ 0.000000] BIOS-e820: 00000000d84c6000 - 00000000d8605000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000d8605000 - 00000000d9fff000 (reserved)
[ 0.000000] BIOS-e820: 00000000d9fff000 - 00000000da000000 (usable)
[ 0.000000] BIOS-e820: 00000000db000000 - 00000000df200000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000011ee00000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. H97M-HD3/H97M-HD3, BIOS F7 04/21/2015
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xda000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7F00000000 write-back
[ 0.000000] 1 base 0100000000 mask 7FE0000000 write-back
[ 0.000000] 2 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 3 base 00DC000000 mask 7FFC000000 uncachable
[ 0.000000] 4 base 00DB000000 mask 7FFF000000 uncachable
[ 0.000000] 5 base 011F000000 mask 7FFF000000 uncachable
[ 0.000000] 6 base 011EE00000 mask 7FFFE00000 uncachable
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000db000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd6e0] fd6e0
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3651e000 - 37287000
[ 0.000000] ACPI: RSDP 000f0490 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT d85ca078 00074 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP d85da940 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT d85ca188 107B7 (v02 ALASKA A M I 00000088 INTL 20120711)
[ 0.000000] ACPI: FACS d8603080 00040
[ 0.000000] ACPI: APIC d85daa50 00072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT d85daac8 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: SSDT d85dab10 00BEE (v01 Ther_R Ther_Rvp 00001000 INTL 20120711)
[ 0.000000] ACPI: SSDT d85db700 00539 (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT d85dbc40 00B74 (v01 CpuRef CpuSsdt 00003000 INTL 20051117)
[ 0.000000] ACPI: MCFG d85dc7b8 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET d85dc7f8 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT d85dc830 0036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[ 0.000000] ACPI: SSDT d85dcba0 05B5E (v01 SaSsdt SaSsdt 00003000 INTL 20120711)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2600MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000da000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009d
[ 0.000000] 0: 0x00000100 -> 0x000c57df
[ 0.000000] 0: 0x000c57e6 -> 0x000c6131
[ 0.000000] 0: 0x000c63e1 -> 0x000d83f6
[ 0.000000] 0: 0x000d8460 -> 0x000d84c6
[ 0.000000] 0: 0x000d9fff -> 0x000da000
[ 0.000000] On node 0 totalpages: 885043
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f49de200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3949 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 5201 pages used for memmap
[ 0.000000] HighMem zone: 652631 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at df200000 (gap: df200000:18e00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 878066
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=1a02de4f-5ef1-4ef6-95b7-4f6cfdf3b53a ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 7143296 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000da000)
[ 0.000000] Memory: 3484548k/3571712k available (3495k kernel code, 55624k reserved, 1237k data, 416k init, 2631328k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3591.786 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 7183.57 BogoMIPS (lpj=14367144)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000024] Security Framework initialized
[ 0.000027] AppArmor: AppArmor disabled by boot time parameter
[ 0.000036] Mount-cache hash table entries: 512
[ 0.000135] Initializing cgroup subsys cpuacct
[ 0.000137] Initializing cgroup subsys memory
[ 0.000140] Initializing cgroup subsys devices
[ 0.000141] Initializing cgroup subsys freezer
[ 0.000142] Initializing cgroup subsys net_cls
[ 0.000143] Initializing cgroup subsys blkio
[ 0.000146] Initializing cgroup subsys perf_event
[ 0.000162] CPU: Physical Processor ID: 0
[ 0.000162] CPU: Processor Core ID: 0
[ 0.001583] mce: CPU supports 7 MCE banks
[ 0.001591] CPU0: Thermal monitoring enabled (TM1)
[ 0.001645] ACPI: Core revision 20120320
[ 0.010313] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.010631] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.050302] CPU0: Intel(R) Core(TM) i3-4160 CPU @ 3.60GHz stepping 03
[ 0.154673] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver.
[ 0.154677] ... version: 3
[ 0.154678] ... bit width: 48
[ 0.154679] ... generic registers: 4
[ 0.154680] ... value mask: 0000ffffffffffff
[ 0.154681] ... max period: 000000007fffffff
[ 0.154682] ... fixed-purpose events: 3
[ 0.154683] ... event mask: 000000070000000f
[ 0.166708] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.178687] CPU 1 irqstacks, hard=f3cf6000 soft=f3cf8000
[ 0.178688] Booting Node 0, Processors #1
[ 0.188877] Initializing CPU#1
[ 0.193210] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.198682] CPU 2 irqstacks, hard=f3d28000 soft=f3d2a000
[ 0.198683] #2
[ 0.208875] Initializing CPU#2
[ 0.213205] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.218675] CPU 3 irqstacks, hard=f3d3c000 soft=f3d3e000
[ 0.218676] #3 Ok.
[ 0.228864] Initializing CPU#3
[ 0.233197] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.233216] Brought up 4 CPUs
[ 0.233218] Total of 4 processors activated (28734.28 BogoMIPS).
[ 0.235386] devtmpfs: initialized
[ 0.235517] PM: Registering ACPI NVS region [mem 0xc57df000-0xc57e5fff] (28672 bytes)
[ 0.235519] PM: Registering ACPI NVS region [mem 0xd84c6000-0xd8604fff] (1306624 bytes)
[ 0.235599] dummy:
[ 0.235631] NET: Registered protocol family 16
[ 0.235698] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.235699] ACPI: bus type pci registered
[ 0.235729] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.235731] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.235732] PCI: Using MMCONFIG for extended config space
[ 0.235733] PCI: Using configuration type 1 for base access
[ 0.236085] bio: create slab <bio-0> at 0
[ 0.236141] ACPI: Added _OSI(Module Device)
[ 0.236143] ACPI: Added _OSI(Processor Device)
[ 0.236144] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.236145] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.238547] ACPI: EC: Look up EC in DSDT
[ 0.241841] ACPI: Executed 15 blocks of module-level executable AML code
[ 0.246143] ACPI: SSDT d842ec18 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.246773] ACPI: Dynamic OEM Table Load:
[ 0.246775] ACPI: SSDT (null) 003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.246980] ACPI: SSDT d842e618 005AA (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.247684] ACPI: Dynamic OEM Table Load:
[ 0.247686] ACPI: SSDT (null) 005AA (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.247773] ACPI: SSDT d842dd98 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.248399] ACPI: Dynamic OEM Table Load:
[ 0.248400] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.249360] ACPI: Interpreter enabled
[ 0.249371] ACPI: (supports S0 S3 S4 S5)
[ 0.249392] ACPI: Using IOAPIC for interrupt routing
[ 0.249681] ACPI: Power Resource [PG00] (on)
[ 0.249983] ACPI: Power Resource [PG01] (on)
[ 0.250281] ACPI: Power Resource [PG02] (on)
[ 0.255420] ACPI: Power Resource [FN00] (off)
[ 0.255470] ACPI: Power Resource [FN01] (off)
[ 0.255521] ACPI: Power Resource [FN02] (off)
[ 0.255569] ACPI: Power Resource [FN03] (off)
[ 0.255619] ACPI: Power Resource [FN04] (off)
[ 0.256204] ACPI: No dock devices found.
[ 0.256209] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.256515] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.256979] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.256980] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.256981] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.256983] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
[ 0.256984] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.256985] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.256986] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.256987] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.256989] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.256990] pci_root PNP0A08:00: host bridge window [mem 0xdf200000-0xfeafffff]
[ 0.257008] PCI host bridge to bus 0000:00
[ 0.257009] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.257011] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.257012] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.257013] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[ 0.257014] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.257015] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.257017] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.257018] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.257019] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.257020] pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff]
[ 0.257026] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.257051] pci 0000:00:02.0: [8086:041e] type 00 class 0x030000
[ 0.257060] pci 0000:00:02.0: reg 10: [mem 0xf7800000-0xf7bfffff 64bit]
[ 0.257065] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.257068] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.257088] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
[ 0.257094] pci 0000:00:03.0: reg 10: [mem 0xf7e14000-0xf7e17fff 64bit]
[ 0.257138] pci 0000:00:14.0: [8086:8cb1] type 00 class 0x0c0330
[ 0.257154] pci 0000:00:14.0: reg 10: [mem 0xf7e00000-0xf7e0ffff 64bit]
[ 0.257197] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.257214] pci 0000:00:16.0: [8086:8cba] type 00 class 0x078000
[ 0.257230] pci 0000:00:16.0: reg 10: [mem 0xf7e1c000-0xf7e1c00f 64bit]
[ 0.257276] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.257301] pci 0000:00:1a.0: [8086:8cad] type 00 class 0x0c0320
[ 0.257319] pci 0000:00:1a.0: reg 10: [mem 0xf7e1b000-0xf7e1b3ff]
[ 0.257382] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.257404] pci 0000:00:1b.0: [8086:8ca0] type 00 class 0x040300
[ 0.257416] pci 0000:00:1b.0: reg 10: [mem 0xf7e10000-0xf7e13fff 64bit]
[ 0.257460] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.257476] pci 0000:00:1c.0: [8086:8c90] type 01 class 0x060400
[ 0.257520] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.257539] pci 0000:00:1c.2: [8086:8c94] type 01 class 0x060400
[ 0.257583] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.257600] pci 0000:00:1c.3: [8086:8c96] type 01 class 0x060400
[ 0.257645] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.257670] pci 0000:00:1d.0: [8086:8ca6] type 00 class 0x0c0320
[ 0.257687] pci 0000:00:1d.0: reg 10: [mem 0xf7e1a000-0xf7e1a3ff]
[ 0.257751] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.257771] pci 0000:00:1f.0: [8086:8cc6] type 00 class 0x060100
[ 0.257868] pci 0000:00:1f.2: [8086:8c82] type 00 class 0x010601
[ 0.257881] pci 0000:00:1f.2: reg 10: [io 0xf0b0-0xf0b7]
[ 0.257887] pci 0000:00:1f.2: reg 14: [io 0xf0a0-0xf0a3]
[ 0.257893] pci 0000:00:1f.2: reg 18: [io 0xf090-0xf097]
[ 0.257899] pci 0000:00:1f.2: reg 1c: [io 0xf080-0xf083]
[ 0.257905] pci 0000:00:1f.2: reg 20: [io 0xf060-0xf07f]
[ 0.257911] pci 0000:00:1f.2: reg 24: [mem 0xf7e19000-0xf7e197ff]
[ 0.257934] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.257945] pci 0000:00:1f.3: [8086:8ca2] type 00 class 0x0c0500
[ 0.257957] pci 0000:00:1f.3: reg 10: [mem 0xf7e18000-0xf7e180ff 64bit]
[ 0.257975] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.258024] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.258078] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.258094] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.258120] pci 0000:02:00.0: reg 18: [mem 0xf7d00000-0xf7d00fff 64bit]
[ 0.258137] pci 0000:02:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.258184] pci 0000:02:00.0: supports D1 D2
[ 0.258185] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.262660] pci 0000:00:1c.2: PCI bridge to [bus 02-02]
[ 0.262662] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.262665] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.262669] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.262718] pci 0000:03:00.0: [8086:244e] type 01 class 0x060401
[ 0.262821] pci 0000:03:00.0: supports D1 D2
[ 0.262821] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.262844] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[ 0.262848] pci 0000:00:1c.3: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.262915] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.262938] pci 0000:04:00.0: reg 10: [mem 0xf7c00000-0xf7c0ffff]
[ 0.263109] pci 0000:03:00.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.263122] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.263131] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.263133] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff] (subtractive decode)
[ 0.263134] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.263135] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.263156] pci_bus 0000:00: on NUMA node 0
[ 0.263158] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.263296] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.263330] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.263364] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.263471] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.272305] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 6 10 *11 12 14 15)
[ 0.272340] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 6 10 11 12 14 15) *0, disabled.
[ 0.272375] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 6 10 *11 12 14 15)
[ 0.272408] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 6 *10 11 12 14 15)
[ 0.272441] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 6 10 11 12 14 15) *0, disabled.
[ 0.272475] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 6 10 11 12 14 15) *0, disabled.
[ 0.272508] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 6 *10 11 12 14 15)
[ 0.272541] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 6 10 *11 12 14 15)
[ 0.272584] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.272589] vgaarb: loaded
[ 0.272590] vgaarb: bridge control possible 0000:00:02.0
[ 0.272603] PCI: Using ACPI for IRQ routing
[ 0.273819] PCI: pci_cache_line_size set to 64 bytes
[ 0.273871] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[ 0.273873] reserve RAM buffer: 00000000c57df000 - 00000000c7ffffff
[ 0.273874] reserve RAM buffer: 00000000c6131000 - 00000000c7ffffff
[ 0.273875] reserve RAM buffer: 00000000d83f6000 - 00000000dbffffff
[ 0.273877] reserve RAM buffer: 00000000d84c6000 - 00000000dbffffff
[ 0.273878] reserve RAM buffer: 00000000da000000 - 00000000dbffffff
[ 0.273948] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.273953] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.275965] Switching to clocksource hpet
[ 0.276000] pnp: PnP ACPI init
[ 0.276005] ACPI: bus type pnp registered
[ 0.276256] pnp 00:00: [bus 00-3e]
[ 0.276257] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.276259] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.276260] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.276261] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.276262] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.276263] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.276264] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.276266] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.276267] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.276268] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.276269] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.276270] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.276271] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.276272] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.276273] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.276274] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.276276] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.276277] pnp 00:00: [mem 0xdf200000-0xfeafffff window]
[ 0.276278] pnp 00:00: [mem 0x00010000-0x0001ffff window]
[ 0.276312] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.276364] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.276387] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.276388] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.276395] pnp 00:02: [io 0x0000-0x001f]
[ 0.276396] pnp 00:02: [io 0x0081-0x0091]
[ 0.276397] pnp 00:02: [io 0x0093-0x009f]
[ 0.276398] pnp 00:02: [io 0x00c0-0x00df]
[ 0.276399] pnp 00:02: [dma 4]
[ 0.276414] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.276419] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.276434] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.276483] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.276499] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.276514] pnp 00:05: [io 0x00f0]
[ 0.276519] pnp 00:05: [irq 13]
[ 0.276535] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.276550] pnp 00:06: [io 0x0800-0x087f]
[ 0.276574] system 00:06: [io 0x0800-0x087f] has been reserved
[ 0.276575] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.276580] pnp 00:07: [io 0x0070-0x0077]
[ 0.276583] pnp 00:07: [irq 8]
[ 0.276599] pnp 00:07: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.276611] pnp 00:08: [io 0x1854-0x1857]
[ 0.276633] system 00:08: [io 0x1854-0x1857] has been reserved
[ 0.276635] system 00:08: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.276712] pnp 00:09: [io 0x0000-0xffffffff disabled]
[ 0.276713] pnp 00:09: [io 0x0a00-0x0a0f]
[ 0.276714] pnp 00:09: [io 0x0a30-0x0a3f]
[ 0.276715] pnp 00:09: [io 0x0a20-0x0a2f]
[ 0.276739] system 00:09: [io 0x0a00-0x0a0f] has been reserved
[ 0.276741] system 00:09: [io 0x0a30-0x0a3f] has been reserved
[ 0.276742] system 00:09: [io 0x0a20-0x0a2f] has been reserved
[ 0.276743] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.276942] pnp 00:0a: [io 0x03f8-0x03ff]
[ 0.276945] pnp 00:0a: [irq 4]
[ 0.276947] pnp 00:0a: [dma 0 disabled]
[ 0.276980] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.277245] pnp 00:0b: [io 0x0378-0x037f]
[ 0.277248] pnp 00:0b: [irq 5]
[ 0.277249] pnp 00:0b: [dma 0 disabled]
[ 0.277353] pnp 00:0b: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.277366] pnp 00:0c: [io 0x0010-0x001f]
[ 0.277367] pnp 00:0c: [io 0x0022-0x003f]
[ 0.277368] pnp 00:0c: [io 0x0044-0x005f]
[ 0.277369] pnp 00:0c: [io 0x0062-0x0063]
[ 0.277370] pnp 00:0c: [io 0x0065-0x006f]
[ 0.277371] pnp 00:0c: [io 0x0072-0x007f]
[ 0.277372] pnp 00:0c: [io 0x0080]
[ 0.277373] pnp 00:0c: [io 0x0084-0x0086]
[ 0.277374] pnp 00:0c: [io 0x0088]
[ 0.277375] pnp 00:0c: [io 0x008c-0x008e]
[ 0.277376] pnp 00:0c: [io 0x0090-0x009f]
[ 0.277377] pnp 00:0c: [io 0x00a2-0x00bf]
[ 0.277378] pnp 00:0c: [io 0x00e0-0x00ef]
[ 0.277380] pnp 00:0c: [io 0x04d0-0x04d1]
[ 0.277406] system 00:0c: [io 0x04d0-0x04d1] has been reserved
[ 0.277408] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.277746] pnp 00:0d: [mem 0xfed1c000-0xfed1ffff]
[ 0.277747] pnp 00:0d: [mem 0xfed10000-0xfed17fff]
[ 0.277748] pnp 00:0d: [mem 0xfed18000-0xfed18fff]
[ 0.277750] pnp 00:0d: [mem 0xfed19000-0xfed19fff]
[ 0.277751] pnp 00:0d: [mem 0xf8000000-0xfbffffff]
[ 0.277752] pnp 00:0d: [mem 0xfed20000-0xfed3ffff]
[ 0.277753] pnp 00:0d: [mem 0xfed90000-0xfed93fff]
[ 0.277754] pnp 00:0d: [mem 0xfed45000-0xfed8ffff]
[ 0.277755] pnp 00:0d: [mem 0xff000000-0xffffffff]
[ 0.277756] pnp 00:0d: [mem 0xfee00000-0xfeefffff]
[ 0.277757] pnp 00:0d: [mem 0xf7fe0000-0xf7feffff]
[ 0.277793] system 00:0d: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.277795] system 00:0d: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.277796] system 00:0d: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.277798] system 00:0d: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.277799] system 00:0d: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.277800] system 00:0d: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.277803] system 00:0d: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.277804] system 00:0d: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.277805] system 00:0d: [mem 0xff000000-0xffffffff] has been reserved
[ 0.277807] system 00:0d: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.277808] system 00:0d: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.277810] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.277954] pnp: PnP ACPI: found 14 devices
[ 0.277954] ACPI: ACPI bus type pnp unregistered
[ 0.277956] PnPBIOS: Disabled by ACPI PNP
[ 0.313603] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.313612] pci 0000:00:1c.2: PCI bridge to [bus 02-02]
[ 0.313614] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.313618] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.313621] pci 0000:00:1c.2: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.313625] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 0.313632] pci 0000:03:00.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.313645] pci 0000:00:1c.3: PCI bridge to [bus 03-04]
[ 0.313649] pci 0000:00:1c.3: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.313686] pci 0000:03:00.0: setting latency timer to 64
[ 0.313690] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.313691] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.313692] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.313693] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.313694] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.313695] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.313696] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.313698] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.313699] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.313700] pci_bus 0000:00: resource 13 [mem 0xdf200000-0xfeafffff]
[ 0.313701] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.313702] pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.313704] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.313705] pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.313706] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.313707] pci_bus 0000:04: resource 5 [mem 0xf7c00000-0xf7cfffff]
[ 0.313758] NET: Registered protocol family 2
[ 0.313790] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.313884] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.314037] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.314131] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.314132] TCP: reno registered
[ 0.314134] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.314138] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.314185] NET: Registered protocol family 1
[ 0.314191] pci 0000:00:02.0: Boot video device
[ 0.314472] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.314478] pci 0000:00:14.0: power state changed by ACPI to D0
[ 0.351973] PCI: CLS 64 bytes, default 64
[ 0.351997] Unpacking initramfs...
[ 0.519165] Freeing initrd memory: 13732k freed
[ 0.520770] audit: initializing netlink socket (disabled)
[ 0.520781] type=2000 audit(1480669141.412:1): initialized
[ 0.528425] highmem bounce pool size: 64 pages
[ 0.528428] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.528567] VFS: Disk quotas dquot_6.5.2
[ 0.528584] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.528627] msgmni has been set to 1693
[ 0.528727] alg: No test for stdrng (krng)
[ 0.528745] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.528747] io scheduler noop registered
[ 0.528748] io scheduler deadline registered
[ 0.528765] io scheduler cfq registered (default)
[ 0.528899] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.528908] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.528909] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.529111] acpiphp: Slot [1] registered
[ 0.529243] GHES: HEST is not enabled!
[ 0.529250] isapnp: Scanning for PnP cards...
[ 0.881467] isapnp: No Plug & Play device found
[ 0.881491] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.901831] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.922337] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.922510] Linux agpgart interface v0.103
[ 0.922597] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.922980] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.922987] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.923044] mousedev: PS/2 mouse device common for all mice
[ 0.923077] rtc_cmos 00:07: RTC can wake from S4
[ 0.923176] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 0.923198] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.923276] TCP: cubic registered
[ 0.923317] NET: Registered protocol family 10
[ 0.923434] Mobile IPv6
[ 0.923435] NET: Registered protocol family 17
[ 0.923437] Registering the dns_resolver key type
[ 0.923468] Using IPI No-Shortcut mode
[ 0.923520] PM: Hibernation image not present or could not be loaded.
[ 0.923525] registered taskstats version 1
[ 0.923926] rtc_cmos 00:07: setting system clock to 2016-12-02 08:59:02 UTC (1480669142)
[ 0.923992] Freeing unused kernel memory: 416k freed
[ 0.924063] Write protecting the kernel text: 3496k
[ 0.924076] Write protecting the kernel read-only data: 984k
[ 0.929913] udevd[58]: starting version 175
[ 0.941719] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 0.941763] r8169 0000:02:00.0: (unregistered net_device): unknown MAC, using family default
[ 0.942049] r8169 0000:02:00.0: eth0: RTL8168b/8111b at 0xf802e000, 40:8d:5c:41:e1:33, XID 0c000800 IRQ 18
[ 0.942052] r8169 0000:02:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko]
[ 0.942562] usbcore: registered new interface driver usbfs
[ 0.942579] usbcore: registered new interface driver hub
[ 0.952033] usbcore: registered new device driver usb
[ 0.952339] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.952388] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 0.952392] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 0.952409] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 0.952430] ehci_hcd 0000:00:1a.0: debug port 2
[ 0.953451] SCSI subsystem initialized
[ 0.955131] ACPI: Fan [FAN0] (off)
[ 0.957305] microcode: CPU0 sig=0x306c3, pf=0x2, revision=0x1c
[ 0.960837] libata version 3.00 loaded.
[ 0.960885] ACPI: Fan [FAN1] (off)
[ 0.960923] ACPI: Fan [FAN2] (off)
[ 0.960952] ACPI: Fan [FAN3] (off)
[ 0.960981] ACPI: Fan [FAN4] (off)
[ 0.965477] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 0.965497] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7e1b000
[ 0.972426] microcode: CPU1 sig=0x306c3, pf=0x2, revision=0x1c
[ 0.973552] microcode: CPU2 sig=0x306c3, pf=0x2, revision=0x1c
[ 0.974673] microcode: CPU3 sig=0x306c3, pf=0x2, revision=0x1c
[ 0.975757] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 0.975776] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.975777] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.975779] usb usb1: Product: EHCI Host Controller
[ 0.975780] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 0.975781] usb usb1: SerialNumber: 0000:00:1a.0
[ 0.975856] hub 1-0:1.0: USB hub found
[ 0.975858] hub 1-0:1.0: 2 ports detected
[ 0.975859] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 0.975941] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.975944] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 0.975950] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.975967] ehci_hcd 0000:00:1d.0: debug port 2
[ 0.979855] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 0.979868] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7e1a000
[ 0.991725] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.991736] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.991738] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.991739] usb usb2: Product: EHCI Host Controller
[ 0.991741] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 0.991742] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.991809] hub 2-0:1.0: USB hub found
[ 0.991811] hub 2-0:1.0: 2 ports detected
[ 0.991858] ahci 0000:00:1f.2: version 3.0
[ 0.991914] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x1 impl SATA mode
[ 0.991917] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[ 0.991921] ahci 0000:00:1f.2: setting latency timer to 64
[ 0.992322] scsi0 : ahci
[ 0.992475] scsi1 : ahci
[ 0.992530] scsi2 : ahci
[ 0.992730] scsi3 : ahci
[ 0.992895] scsi4 : ahci
[ 0.993391] scsi5 : ahci
[ 0.993849] ata1: SATA max UDMA/133 abar m2048@0xf7e19000 port 0xf7e19100 irq 19
[ 0.993851] ata2: DUMMY
[ 0.993852] ata3: DUMMY
[ 0.993852] ata4: DUMMY
[ 0.993853] ata5: DUMMY
[ 0.993854] ata6: DUMMY
[ 0.993887] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 0.993891] xhci_hcd 0000:00:14.0: power state changed by ACPI to D0
[ 0.993917] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 0.993920] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.993927] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.994008] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.994029] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.994030] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.994031] usb usb3: Product: xHCI Host Controller
[ 0.994032] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 0.994033] usb usb3: SerialNumber: 0000:00:14.0
[ 0.994088] xHCI xhci_add_endpoint called for root hub
[ 0.994090] xHCI xhci_check_bandwidth called for root hub
[ 0.994114] hub 3-0:1.0: USB hub found
[ 0.994130] hub 3-0:1.0: 14 ports detected
[ 0.994196] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.994199] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.994213] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.994214] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.994216] usb usb4: Product: xHCI Host Controller
[ 0.994217] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 0.994218] usb usb4: SerialNumber: 0000:00:14.0
[ 0.994253] xHCI xhci_add_endpoint called for root hub
[ 0.994255] xHCI xhci_check_bandwidth called for root hub
[ 0.994274] hub 4-0:1.0: USB hub found
[ 0.994284] hub 4-0:1.0: 6 ports detected
[ 1.287621] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.311615] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.325720] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.325723] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.325724] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.333201] ata1.00: ATA-8: KINGSTON SV300S37A120G, 603ABBF0, max UDMA/133
[ 1.333203] ata1.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 1.338535] ata1.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.338537] ata1.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.338539] ata1.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.343889] ata1.00: configured for UDMA/133
[ 1.343961] scsi 0:0:0:0: Direct-Access ATA KINGSTON SV300S3 603A PQ: 0 ANSI: 5
[ 1.346487] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 1.346529] sd 0:0:0:0: [sda] Write Protect is off
[ 1.346532] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.346545] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.346909] sda: sda1 sda2 < sda5 >
[ 1.347073] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.347964] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.419880] usb 1-1: New USB device found, idVendor=8087, idProduct=8009
[ 1.419882] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.420018] hub 1-1:1.0: USB hub found
[ 1.420128] hub 1-1:1.0: 6 ports detected
[ 1.519536] Refined TSC clocksource calibration: 3591.682 MHz.
[ 1.519540] Switching to clocksource tsc
[ 1.531532] usb 2-1: new high-speed USB device number 2 using ehci_hcd
[ 1.663785] usb 2-1: New USB device found, idVendor=8087, idProduct=8001
[ 1.663786] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.663939] hub 2-1:1.0: USB hub found
[ 1.664036] hub 2-1:1.0: 8 ports detected
[ 1.735514] usb 1-1.5: new low-speed USB device number 3 using ehci_hcd
[ 1.831603] usb 1-1.5: New USB device found, idVendor=046d, idProduct=c077
[ 1.831605] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.831606] usb 1-1.5: Product: USB Optical Mouse
[ 1.831607] usb 1-1.5: Manufacturer: Logitech
[ 1.834678] input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.5/1-1.5:1.0/input/input0
[ 1.834723] generic-usb 0003:046D:C077.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1a.0-1.5/input0
[ 1.834732] usbcore: registered new interface driver usbhid
[ 1.834733] usbhid: USB HID core driver
[ 1.903456] usb 1-1.6: new low-speed USB device number 4 using ehci_hcd
[ 2.001555] usb 1-1.6: New USB device found, idVendor=1c4f, idProduct=0002
[ 2.001557] usb 1-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.001558] usb 1-1.6: Product: USB Keyboard
[ 2.001559] usb 1-1.6: Manufacturer: SIGMACHIP
[ 2.004128] input: SIGMACHIP USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.0/input/input1
[ 2.004159] generic-usb 0003:1C4F:0002.0002: input,hidraw1: USB HID v1.10 Keyboard [SIGMACHIP USB Keyboard] on usb-0000:00:1a.0-1.6/input0
[ 2.006882] input: SIGMACHIP USB Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.6/1-1.6:1.1/input/input2
[ 2.006909] generic-usb 0003:1C4F:0002.0003: input,hidraw2: USB HID v1.10 Device [SIGMACHIP USB Keyboard] on usb-0000:00:1a.0-1.6/input1
[ 2.075389] usb 2-1.6: new high-speed USB device number 3 using ehci_hcd
[ 2.170741] usb 2-1.6: New USB device found, idVendor=0718, idProduct=0619
[ 2.170743] usb 2-1.6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.170744] usb 2-1.6: Product: TF10
[ 2.170745] usb 2-1.6: Manufacturer: TDK LoR
[ 2.170746] usb 2-1.6: SerialNumber: 0703514F819E7355
[ 2.171931] Initializing USB Mass Storage driver...
[ 2.171997] scsi6 : usb-storage 2-1.6:1.0
[ 2.172035] usbcore: registered new interface driver usb-storage
[ 2.172036] USB Mass Storage support registered.
[ 3.171755] scsi 6:0:0:0: Direct-Access TDK LoR TF10 PMAP PQ: 0 ANSI: 6
[ 3.172013] sd 6:0:0:0: Attached scsi generic sg1 type 0
[ 3.173624] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[ 6.437825] PM: Starting manual resume from disk
[ 6.437827] PM: Hibernation image partition 8:5 present
[ 6.437828] PM: Looking for hibernation image.
[ 6.437986] PM: Image not found (code -22)
[ 6.437988] PM: Hibernation image not present or could not be loaded.
[ 6.445110] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.558226] udevd[424]: starting version 175
[ 6.591417] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 6.591423] ACPI: Power Button [PWRB]
[ 6.591463] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4
[ 6.591466] ACPI: Sleep Button [SLPB]
[ 6.591501] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5
[ 6.591503] ACPI: Power Button [PWRF]
[ 6.617814] udevd[478]: renamed network interface eth0 to eth1
[ 6.618785] parport_pc 00:0b: reported by Plug and Play ACPI
[ 6.618830] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[ 9.656588] hda-intel: azx_get_response timeout, switching to polling mode: last cmd=0x000f0000
[ 10.660220] hda-intel: Codec #0 probe error; disabling it...
[ 11.679852] hda_intel: azx_get_response timeout, switching to single_cmd mode: last cmd=0x000f0001
[ 11.728496] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card1/input6
[ 11.728551] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input7
[ 11.728596] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input8
[ 11.728640] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input9
[ 11.728683] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card1/input10
[ 11.864027] Adding 4789244k swap on /dev/sda5. Priority:-1 extents:1 across:4789244k SS
[ 11.870753] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 11.890319] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 11.901691] loop: module loaded
[ 12.190016] RPC: Registered named UNIX socket transport module.
[ 12.190018] RPC: Registered udp transport module.
[ 12.190019] RPC: Registered tcp transport module.
[ 12.190020] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 12.192761] FS-Cache: Loaded
[ 12.195864] NFS: Registering the id_resolver key type
[ 12.195878] FS-Cache: Netfs 'nfs' registered for caching
[ 12.198022] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 12.484259] Bluetooth: Core ver 2.16
[ 12.484271] NET: Registered protocol family 31
[ 12.484273] Bluetooth: HCI device and connection manager initialized
[ 12.484274] Bluetooth: HCI socket layer initialized
[ 12.484276] Bluetooth: L2CAP socket layer initialized
[ 12.484279] Bluetooth: SCO socket layer initialized
[ 12.488831] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 12.488833] Bluetooth: BNEP filters: protocol multicast
[ 12.490402] Bluetooth: RFCOMM TTY layer initialized
[ 12.490406] Bluetooth: RFCOMM socket layer initialized
[ 12.490407] Bluetooth: RFCOMM ver 1.11
[ 12.513210] lp0: using parport0 (interrupt-driven).
[ 12.515397] ppdev: user-space parallel port driver
[ 12.568170] r8169 0000:02:00.0: eth1: link down
[ 12.568219] r8169 0000:02:00.0: eth1: link down
[ 12.568253] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 13.388425] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input11
[ 14.398718] r8169 0000:02:00.0: eth1: link up
[ 14.398766] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 24.807087] eth1: no IPv6 routers present
[ 83.878333] I-pipe: head domain RTAI registered.
[ 83.878337] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 83.878383] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 83.878385] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591786000, CPU_FREQ 3591786000
[ 83.878386] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 83.878388] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6203500
[ 83.886033] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 83.886055] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 83.886058] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 83.886060] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591786000 hz.
[ 83.886061] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 83.892320] RTAI[math]: loaded.
[ 83.927909] hm2: loading Mesa HostMot2 driver version 0.15
[ 83.929301] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 83.929324] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 83.929800] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 83.987135] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 83.990193] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 83.992723] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 83.997356] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 84.003208] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 84.105978] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 84.108627] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 84.208137] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 84.208138] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 84.208140] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 84.208141] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 84.208143] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 84.208144] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 84.208145] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 84.208147] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 84.208148] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 84.208150] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 84.208151] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 84.208152] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 84.208154] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 84.208155] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 84.208156] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 84.208158] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 84.208159] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 84.208160] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 84.208161] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 84.208162] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 84.208163] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 84.208164] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 84.208165] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 84.208166] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 84.208168] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 84.208169] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 84.208170] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 84.208171] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 84.208172] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 84.208173] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 84.208174] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 84.208175] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 84.208176] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 84.208177] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 84.208178] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 84.208207] hm2/hm2_5i25.0: registered
[ 84.208208] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 84.405592] milltask[4307]: segfault at 0 ip 0808a62f sp bfb3c540 error 4 in milltask[8048000+66000]
[ 89.599977] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 89.599980] hm2/hm2_5i25.0: unregistered
[ 89.600005] hm2_pci: driver unloaded
[ 89.600830] hm2: unloading
[ 91.653772] RTAI[math]: unloaded.
[ 91.654599] SCHED releases registered named ALIEN PEDV$D
[ 91.656931] RTAI[malloc]: unloaded.
[ 91.754852] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 91.755809] I-pipe: head domain RTAI unregistered.
[ 91.755859] RTAI[hal]: unmounted.
[ 762.072031] I-pipe: head domain RTAI registered.
[ 762.072035] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 762.072080] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 762.072083] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591786000, CPU_FREQ 3591786000
[ 762.072093] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 762.072095] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6225750
[ 762.075013] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 762.075030] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 762.075032] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 762.075034] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591786000 hz.
[ 762.075035] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 762.080923] RTAI[math]: loaded.
[ 762.107319] hm2: loading Mesa HostMot2 driver version 0.15
[ 762.108220] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 762.108244] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 762.108748] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 762.165887] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 762.168630] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 762.171107] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 762.175533] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 762.181324] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 762.283850] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 762.286500] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 762.386055] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 762.386057] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 762.386058] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 762.386059] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 762.386061] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 762.386063] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 762.386064] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 762.386065] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 762.386067] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 762.386068] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 762.386070] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 762.386071] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 762.386072] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 762.386073] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 762.386075] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 762.386076] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 762.386077] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 762.386079] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 762.386080] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 762.386081] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 762.386082] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 762.386083] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 762.386084] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 762.386085] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 762.386086] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 762.386087] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 762.386088] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 762.386089] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 762.386090] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 762.386091] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 762.386092] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 762.386093] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 762.386094] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 762.386095] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 762.386096] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 762.386126] hm2/hm2_5i25.0: registered
[ 762.386127] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 762.490810] milltask[4598]: segfault at 0 ip 0808a62f sp bfd6b070 error 4 in milltask[8048000+66000]
[ 767.749786] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 767.749789] hm2/hm2_5i25.0: unregistered
[ 767.749815] hm2_pci: driver unloaded
[ 767.750626] hm2: unloading
[ 769.797558] RTAI[math]: unloaded.
[ 769.798392] SCHED releases registered named ALIEN PEDV$D
[ 769.801079] RTAI[malloc]: unloaded.
[ 769.897295] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 769.898177] I-pipe: head domain RTAI unregistered.
[ 769.898228] RTAI[hal]: unmounted.
[ 1102.108900] I-pipe: head domain RTAI registered.
[ 1102.108905] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1102.108960] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1102.108963] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235130, CLK_FREQ 3591786000, CPU_FREQ 3591786000
[ 1102.108967] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1102.108970] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235130, 6235130, 6226000
[ 1102.112000] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1102.112024] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1102.112026] RTAI[sched]: hard timer type/freq = APIC/6235130(Hz); default timing: oneshot; linear timed lists.
[ 1102.112028] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3591786000 hz.
[ 1102.112029] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1102.116381] RTAI[math]: loaded.
[ 1102.142704] hm2: loading Mesa HostMot2 driver version 0.15
[ 1102.143570] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1102.143597] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 1102.144070] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 1102.201307] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 1102.204206] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 1102.206735] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 1102.211368] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 1102.217159] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 1102.319717] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 1102.322367] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 1102.421782] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 1102.421784] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 1102.421785] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 1102.421786] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 1102.421788] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 1102.421789] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 1102.421791] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 1102.421792] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 1102.421794] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 1102.421795] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 1102.421796] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 1102.421798] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 1102.421799] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 1102.421800] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 1102.421802] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 1102.421803] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 1102.421804] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 1102.421806] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 1102.421807] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 1102.421808] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 1102.421809] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 1102.421810] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 1102.421811] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 1102.421812] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 1102.421813] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 1102.421814] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 1102.421815] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 1102.421816] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 1102.421817] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 1102.421818] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 1102.421819] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 1102.421820] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 1102.421821] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 1102.421822] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 1102.421823] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 1102.421853] hm2/hm2_5i25.0: registered
[ 1102.421854] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 1102.524827] milltask[4833]: segfault at 0 ip 0808a62f sp bfa70640 error 4 in milltask[8048000+66000]
[ 1107.782099] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 1107.782102] hm2/hm2_5i25.0: unregistered
[ 1107.782127] hm2_pci: driver unloaded
[ 1107.782916] hm2: unloading
[ 1109.828776] RTAI[math]: unloaded.
[ 1109.829596] SCHED releases registered named ALIEN PEDV$D
[ 1109.832237] RTAI[malloc]: unloaded.
[ 1109.930122] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1109.931060] I-pipe: head domain RTAI unregistered.
[ 1109.931111] RTAI[hal]: unmounted.
or my config is write in wrong way for new master (probabily yes) .... or there are a problem (I hope I'm in wrong).... any how singleton problem is on MASTER BRANCH ....
Regards
Giorgio
02 Dec 2016 10:32 #83566
Replied by andypugh on topic problem with compile custom comp --- library path
I think this is probably a fault in your custom component C-code. Possibly in one of the changes you have made to make it compile.
You could try to decode:using the instructions here
github.com/LinuxCNC/linuxcnc/blob/master/docs/rtfaults.txt
But I think it is probably simpler to _not_ use "option singleton" and accept that the HAL pin names will have ".0." in the middle (possibly using the HAL "alias" command to work round this)
linuxcnc.org/docs/2.7/html/man/man1/halcmd.1.html
Best of all, if you can find out where the problem is in halcompile you could help us fix the bug. However I have had a look and it isn't obvious. The problem seems to be that "option userspace" over-rides "option singleton" in one section of halcompile.g (github.com/LinuxCNC/linuxcnc/blob/master...l/utils/halcompile.g )
The following user(s) said Thank You: bkt
02 Dec 2016 11:49 #83569
by bkt
Replied by bkt on topic problem with compile custom comp --- library path
I can do these ... but:
1- after 1 hour of working my debian 7 freeze .... driver problem ... I'know debian have some of these problem... because the distro is "too stable" (I know many bebian users will hate me for this but unfortunately for the few experiences I've done seems to me that "stable" means "old" ...)
2- my comp is now only without singleton ... and the error that I've been posted came from config with comp DISABLE.
3- my config have CUSTOMKINS.C + CUSTOMCOMP.COMP => in these way CUSTOMKINS.C +CUSTOMCOMP.COMP IT WORKS ON UBUNTU 14.04 BUT NOT IN DEBIAN 7....... see previous post for error at start..
4- on ubuntu 14.04 I've just test the robot with 16hour of working ... but without custom comp and with axis gui ....
5- actually I try to understand because I'm not able to make deb pakage from ubuntu, and because I'm not able to compile k1MbServer.comp..... for shure I can work around halcompile after I've unterstand because Lcnc it seems to not work with uint16 ... in fact the errors I get are all related to the features relative of use pointer and uint16.... ( I'Have some pc with libmodbus 3.1.2 and ubuntu14.04 installed and perfect working)..
Actually is 3 days that work around these problem ... I hope I can solve these today ....
Regards
Giorgio
Regards
Giorgio
21 Dec 2016 17:48 #84504
by bkt
there are not problem with modbus library path .... is problem with compiler option & modbus path on my pc (work ok with cc -Wall ..... But not with gcc ....) .... Definitively my comp works in these way ... mycomp.0.mypin .... but In these xmax holiday I work on these too .....
Giorgio
Giorgio
26 Jan 2017 19:11 - 03 Feb 2017 18:43 #86732
by bkt
So .... my libmodbus path problem is solved install libmodbus5 from repo .... than install libmodbus 1.4 from libmodbus.org git repo ... than install linuxcnc master ....
NOTE: on linuxfoundation.org I see an advice about old kernel (pre 4.8) about timing ... so I decide to try install ubuntu 14.04 with new kernel rt 4.8.15rt10 .... gcc is at 5.4 version
The performance of latency is really better than onld rt 4.5/4.4 .... at the same elapse time the plot is 10 time thin than the older one at the same hardware ....
Now my comp compile with option singleton=no .... some error is correct because some pin name (on off) is too similar to other Lcnc pin so the "parser" in halcompile see it as error ...
with a little 'patience I see if I can sort it out and finally use singleton = yes option...
AFTER 15 MIN ONLY BLUETOOTH, ETH, WIRELESS CONNECTION AND GLXGEARS..
AFTER 1 HOUR WITH GLXGEARS, OPEN AND CLOSE GHAPHICAL PROG. AS INKSCAPE, SCHERMATA, SHOWTELL....
so .... is not good for parport stepgen config .... but good for fpga servo config ...
i add latency histogram ... for share memory ... (these time the result is better than last rt-preempt ubuntu installation)
Regards
Giorgio
Regards
Giorgio
Last edit: 03 Feb 2017 18:43 by bkt.
06 Feb 2017 15:27 - 06 Feb 2017 15:35 #87403
by bkt
My I3 3.3Ghz system on ubuntu 14.04 rt 4.8.15 after add isolcpius 0,1 in GRAB_DEFAULT ...line .. and after DISABLE hiperthreading for cpu in bios setting ... the performance improove ... actualli ubuntu 14.04 is near to become capable to make a stepper control system ....
AFTER 8h OF 4 YOUTUBE VIDEO ON F22 AND F35 ...
WITH 8 GLXGEARS RUN ...
2 things .... the performance of ubuntu 16.04 is better near ubuntu 14.04 so I suspect I re-compile the kernel rt-prreempt on ubuntu 16-04 with xfce or other wm with lower resource consumption the perfermance of base thread become aceptble....
I think the next installation was to linux mint 18 .....
Giorgio
Giorgio
Last edit: 06 Feb 2017 15:35 by bkt.
08 Feb 2017 08:06 - 08 Feb 2017 08:20 #87518
by bkt
whit xfce, same kernel, SO and hardware, the situation is a little better ... after 8h with all connection activated (bluetooth, wifi, eth...) and 2 glxgears (1 in a big windows 1/4 of the 24" screen) the latency is these...
but after 14h the result is a little more better ...
but with unity the base thread in 14h become 78000 .....
latency --nobase it seems stable and plot update not change (with 1 glxgears and with 8 it seems the same) ... but respect unity I see 1E5 ordered line ... almost two units more...
with 8 glxgears the situation not change..
so it seems that: xfce have a better latency but in a long period of test the final test result does not change much ... then the thread basic salt always above 50000, a little 'better for xfce (58000) a bit' worse for unity ( has also risen to 78000 but also was using youtube .... I do not know if it's worth).
Regards
Giorgio
Regards
Giorgio
Last edit: 08 Feb 2017 08:20 by bkt.
08 Feb 2017 13:21 #87542
by bkt
09 Feb 2017 08:23 #87637
by bkt
Time to create page: 0.440 seconds
