both tristate_float & abs_s32 won't load ! (addf fails)
01 Dec 2016 03:26 - 01 Dec 2016 03:44 #83513
by gmouer
both tristate_float & abs_s32 won't load ! (addf fails) was created by gmouer
both tristate_float and abs_s32 components won't load properly
The loadrt line appears to function properly but the failure occurs with the addf line for the respective component.
I am running debian and 2.7.8, installed off the livecd and then updated.
The tristate_float was reported and fixed about a year ago I found on a search, The problem appears to have re-appeared
both of these fail on the addf line
loadrt tristate_float count=1
addf tristate_float.0 servo-thread
loadrt abs_s32 count=1
addf abs_s32.0 servo-thread
(Both components are used in the example hal file for the shuttlexptress included with the 2.7.7 livecd)
I would appreciate someone testing loading these components.
George
George
Last edit: 01 Dec 2016 03:44 by gmouer.
01 Dec 2016 14:20 #83522
Replied by PCW on topic both tristate_float & abs_s32 won't load ! (addf fails)
In both cases, the function name uses a dash instead of a underscore
so:
addf tristate-float.0 servo-thread
addf abs-s32.0 servo-thread
works
Dont ask me why these are named this way
If you have a question about a function name you can just loadrt the component and then:
halcmd show funct
so:
works
halcmd show funct
01 Dec 2016 14:27 #83523
by gmouer
Replied by gmouer on topic both tristate_float & abs_s32 won't load ! (addf fails)
Thanks Pete !
Apparently the example hal file for the shuttlexpress, which is included with the livecd has the syntax of the addf for those components wrong also.
That example hal file for the shuttlexpress should be corrected.
(here is the code, same as included on the livecd. github.com/modmaker/machinekit/blob/mast...on/shuttlexpress.hal)
01 Dec 2016 14:45 #83524
Yeah probably just a bad assumption when those examples were typed in
(and apparently not tested)
The man pages for the components are correct
and
linuxcnc.org/docs/html/hal/comp.html#_syntax
Explains the name munging
and
- Online
- Thank you received: 1369
01 Dec 2016 16:39 #83529
It is right in the example you linked to
Replied by Todd Zuercher on topic both tristate_float & abs_s32 won't load ! (addf fails)
Thanks Pete !
01 Dec 2016 16:46 - 01 Dec 2016 16:48 #83530
by gmouer
Hi Todd,
I used that example code as a basis for writing hal code for my shuttle pro. The pro model is slightly different.
I also found some other problems with the shuttlexpress example hal file. The file references some halui.axis pins which no longer exist in the current lcnc release. That caused pin not found error messages.
in particular : halui.axis.jog-speed , halui.axis.x.plus, halui,axis.x.minus (same for Y and Z axis)
These pins are now relocated into the halui.jog section.
Had a novice like me plenty confused for a while, but I won the battle and my bridgeport has variable speed jog with the shuttle pro working nicely now.
George
Thanks Pete !
Hi Todd,
George
Last edit: 01 Dec 2016 16:48 by gmouer.
02 Dec 2016 14:14 #83575
The reason is that the component name has to match the file name, and "-" is invalid in a Linux file name.
However the standard for HAL pins is (meant to be) all "-" and no "_",
(I didn't say it was a _good_ reason)
Replied by andypugh on topic both tristate_float & abs_s32 won't load ! (addf fails)
The following user(s) said Thank You: gmouer
