Sercos3 Softmaster
15 Feb 2017 19:32 #88011
by roschi
Sercos3 Softmaster was created by roschi
Hello,
I've created a first implementation of a sercos softmaster for machinekit based on that
You can get some Information and first results here
github.com/aschiffler/linuxcnc-sercos3
I have also tested this on a Raspbery Pi3 but this device has no "real" Ethernet controller so in fact this did not work probably (realtime capabilities).
Now I need help or hints according several topics
- What is about RTAI/LinuxCNC?
- How to set up a realiable build config / make files because the main part of the code (Sercos-Softmaster-Core) is hosted on sourceforge an includes no build files;
- Implementation of something like a config application or XML parser like the EtherCAT Driver for MachineKit (act. config is fixed coded)
- Testing any feedback about other experiences or requirements (jitter, functionality,....)
- Feedback / Discussion whether this Sercos3 Driver is senseless or has big potential...
I think the potential of sercos3 is that common Ethernet packets can be routed through the same physical cables/switches without having some like EOE (EtherNet over EtherCAT). Perhaps see the introduction here
Best Regards
Andreas
Best Regards
Andreas
- Thank you received: 5925
20 Feb 2017 04:14 #88320
Replied by tommylight on topic Sercos3 Softmaster
I do not have to much time to check what exactly sercos means as a system, but from a short read i do not see any example where i could use it. Linuxcnc has support for ethernet and works easily with Mesa and Beckhof devices.
Thank you for pointing out, might come handy later on, or after i dig some more into it.
Regards,
Tom
Regards,
Tom
Time to create page: 0.079 seconds
