Mb2hal speed irregular timing of reversing of spindle
- Thank you received: 1369
03 Apr 2017 12:44 #90795
Replied by Todd Zuercher on topic Mb2hal speed irregular timing of reversing of spindle
Glad to hear you were able to sort it out. I wish simply running a shielded cable and grounding it on one end had fixed my com errors, but no luck for me.
- Charlieslasher
03 Apr 2017 21:06 #90817
by Charlieslasher
Replied by Charlieslasher on topic Mb2hal speed irregular timing of reversing of spindle
Could try a diffrent 485 converter. I grounded my sheilding to my converter ground terminal.
Do you get comm errors with the vfd not puting out any frequency. I could see more errors increasing as inverter turned on.
You can decrease carrier frequency of inverter also to limit the emf from the vfd.
03 Apr 2017 21:32 #90820
I've tried at least 3 different ones with varying results from almost usable to totally useless. I get com errors regardless of the running state of the motors. The error rate is arround 40-60% and it bogs things down tremendously.
And it doesn't help matters that I'm trying to control 8 VFDs.
- Charlieslasher
03 Apr 2017 21:49 #90824
by Charlieslasher
Ohh 8 vfds! It seems like everything has to be perfect for modbus to run error free. Have you tried an ociliscope to check the signal.
03 Apr 2017 23:15 #90829
No, but I'm not sure how I'd need to hook it up, or exactly what I'd be looking for when it is hooked up. Although I think we might have gotten a new scope at work since the last time I messed with this. (The old scope was an ancient single trace POS. just this side of useless.) This would give me a good excuse to check it out and play with it a bit.
Time to create page: 0.430 seconds
