Basic HAL help
09 May 2017 00:37 #92897
by dberndt
Basic HAL help was created by dberndt
I need some basic HAL help here.
As a programmer an general sane person working with something like hm2_5i25.0.7i77.0.0.input-02 is pretty much a non-starter. So I want to name some stuff and I'm either not getting the syntax right, or I'm trying to do something that isn't possible.
So lets say I want to take 2 pins, and and2 them together to figure out if I a servo-amp is throwing an error...
#...lots of other garbage...
loadrt and2 count=1
#...more garbage...
addf and2.0 servo-thread
net x-amp-warning <= hm2_5i25.0.7i77.0.0.input-02
net x-amp-on <= hm2_5i25.0.7i77.0.0.input-03-not
#that seems reasonable so far, we've brought in the 2 pins we care about and given them descriptive names. Now lets put those things into an and2.
net and2.0.in0 <= x-amp-warning
net and2.0.in1 <= x-amp-on
Error, pin 'x-amp-warning' does not exist.. Why is it that I can't connect what seems to be a "signal" to another signal? I thought the analogy in the tutorial was that signals are just wires. I can certainly connect wires together in real life... Do I have to makeup a pin to connect these wires at somehow?
Finding this to be a 10/10 on the frustrating scale.
loadrt and2 count=1
#...more garbage...
- Thank you received: 5927
09 May 2017 00:42 #92898
Replied by tommylight on topic Basic HAL help
I think just reversing the order on the last 2 lines is .......well in order !!!
09 May 2017 01:11 #92902
by dberndt
Replied by dberndt on topic Basic HAL help
Well that's awesome...
No:
Yes:
net x-amp-warning => and2.0.in0
net y-amp-ready => and2.0.in1
But... why? They seem to be the same. Lines above like:
Assign the thing on the right to the thing on the left just fine. Why is it reversed in this case?
No:
Yes:
09 May 2017 12:31 #92916
X-amp-warning is a name you gave it, all others are hal componenets in that case.
You can do:
Net x-amp-warning <= hm2_5i25.0.1.pinxxxx-in-or-out >
=> and2.0.in1
That works.
You can do:
=> and2.0.in1
That works.
- Online
- Thank you received: 1369
09 May 2017 13:01 #92920
Replied by Todd Zuercher on topic Basic HAL help
In Hal a "net" command has specific syntax.
net "signal name" "pin names"
The first word after the net is ALWAYS the signal name. This is an arbitrary name that you make up for this signal. It can be a new name or reference an existing signal name.
Next come the pin names, they are specific names of hal pins created by hal components. There can be only one output pin connected to any one signal name, but as many input pins as you like.
Time to create page: 0.235 seconds
