attempted pyVCP panel and now Error on startup
27 Jun 2017 18:10 - 27 Jun 2017 18:36 #95065
by Beezerlm
attempted pyVCP panel and now Error on startup was created by Beezerlm
I just tried the "This is a LED indicator" example from the pyVCP manual and it seems I broke something.
Created a file called tiny.xml wich contained the following:
Then I ran this command from terminal:
here is the output from terminal:
And now I get an error when I boot and I don't know where to go from here. Any help would be appreciated. File attached:
*update* - LinuxCNC will start on second attempt. Perhaps the tiny.xml file should be in a different folder? I put it in the ~Emc2/configs/HEALD folder.
<pyvcp>
<label text="This is a LED indicator"/>
<led/>
</pyvcp>
halrun -I loadusr pyvcp -c mypanel tiny.xml
halcmd: Traceback (most recent call last):
File "/usr/bin/pyvcp", line 99, in <module>
main()
File "/usr/bin/pyvcp", line 87, in main
pycomp=vcpparse.create_vcp(compname=component_name, master=pyvcp0)
File "debian/tmp/usr/lib/python2.6/dist-packages/vcpparse.py", line 177, in create_vcp
File "debian/tmp/usr/lib/python2.6/dist-packages/vcpparse.py", line 47, in read_file
File "/usr/lib/python2.6/xml/dom/minidom.py", line 1918, in parse
return expatbuilder.parse(file)
File "/usr/lib/python2.6/xml/dom/expatbuilder.py", line 922, in parse
fp = open(file, 'rb')
IOError: [Errno 2] No such file or directory: 'tiny.xml'
Last edit: 27 Jun 2017 18:36 by Beezerlm.
27 Jun 2017 18:51 - 27 Jun 2017 18:53 #95068
by Beezerlm
Replied by Beezerlm on topic attempted pyVCP panel and now Error on startup
Ok. so I added this to the .ini file:
And the AXIS GUI will load with the led indicator in the top right corner (I didn't hook up hal pins yet)
My questions are: What do the error messages mean? Do you have to run the "halrun -I loadusr pyvcp -c mypanel tiny.xml" command if you are making a panel to run within AXIS?
PYVCP = tiny.xml
Last edit: 27 Jun 2017 18:53 by Beezerlm.
27 Jun 2017 19:07 - 27 Jun 2017 19:08 #95069
by Beezerlm
Just tested it out and it appears you do not need the aforementioned Terminal command for creating a panel within AXIS.
Last edit: 27 Jun 2017 19:08 by Beezerlm.
27 Jun 2017 21:52 #95076
Replied by andypugh on topic attempted pyVCP panel and now Error on startup
Are you OK now. or are there still problems?
28 Jun 2017 02:36 #95091
by Beezerlm
All is good and working as intended. I thought I made a mess of things when I got the error messages, but everything ended up working out fine.
Time to create page: 0.177 seconds
