HALCOMPILE missing
13 Jun 2018 16:49 #112292
by Tady
HALCOMPILE missing was created by Tady
Hello!
So I have a problem with my LinuxCNC installation. I was following this post
forum.linuxcnc.org/9-installing-linuxcnc...-or-deb?limitstart=0
When i followed Post 1 (RIP install) the system worked but i have problems with glade-3 when I start Glade and try to open a project i get the following error... The following required catalogs are unavailable: gladevcp..
But if I open a terminal and execute...and thenit works...
I'm a total noob when it comes to Linux but I trying to learn
Anyway I tried to install my system following Post2 everything is ok until I try to compile a custom driver.
halcompile is missing.
I searched on google and I don't know how to correct the problem. In one place i read that I shoul run sudo apt-get install linuxcnc-dev but that does not work...
how do I install halcompile on a deb installed linuxcnc
Thank you very much
. /home/tady/linuxcnc-dev/scripts/rip-environment
glade-3
Thank you very much
13 Jun 2018 16:59 #112294
Replied by PCW on topic HALCOMPILE missing
what error does
report?
report?
13 Jun 2018 17:12 #112295
by Tady
Replied by Tady on topic HALCOMPILE missing
E: Unable to locate package linuxcnc-dev
it seems I'm missing a url link
Can someone exlain to me what are the differences between RIP and deb install.. what are pros and cons
13 Jun 2018 17:40 #112300
Replied by andypugh on topic HALCOMPILE missing
halcompile used to be called "comp"
If you have somehow managed to end up with a very old version of LinuxCNC then perhaps it is still called that.
13 Jun 2018 17:48 #112302
by Tady
nope comp doesn't work.
How could I have pulled an old kernel?
I installed Mint 18.1 and 4.9.4 kernel and patch... and I gip pulled the master branch..
13 Jun 2018 18:03 #112305
The LinuxCNC version is independent of the kernel version.
If you built from source then did you omit the "sudo make setuid" as the last step?
13 Jun 2018 19:02 #112314
by Tady
Yes i did. As it is said in the tutorial.
Wah are the cons of running a system RIP? I don't mind if it is RIP as long as if I can get the glade problem fixed
13 Jun 2018 19:30 #112315
The only problem with running a RIP is that you have to do the . ../scripts/rip-environment every time you want to run the software.
(you also need to do this to find halcompile, incidentally)
13 Jun 2018 19:33 #112317
by Tady
ok i will try tor re install as deb packages (i have an extra disk to play with).
Thank you!
Thank you!
13 Jun 2018 19:40 #112318
Have you considered the pre-compiled binaries from buildbot.linuxcnc.org ?
Time to create page: 0.232 seconds
