how to compile the hostmot2 driver files?
30 Jul 2010 05:21 #3523
by KobeYang
how to compile the hostmot2 driver files? was created by KobeYang
Hi all,
I want to modify the driver files of Mesa-hostmot2,but I don't know how to compile it.Can anybody help me?Thanks.
30 Jul 2010 08:36 #3524
Replied by andypugh on topic Re:how to compile the hostmot2 driver files?
KobeYang wrote:
The simplest way is with "comp"
linuxcnc.org/docs/html/hal_comp.html
That can compile realtime component written in C as well as ones written in the "comp" preprocessing language.
You may need to install emc2-dev to get comp:
sudo apt-get install emc2-dev
Then navigate to /src/hal/drivers/mesa-hostmot2 and issue the command
sudo comp --install hostmot2.c (or whichever of the driver files you end up changing)
What changes do you wish to make? It might be easier to write a new component in comp, or the functionality might already be there in another way.
Hi all,
Time to create page: 0.059 seconds
