About Spindle Acceleration Deceleration Ramp
- marq_torque
- Topic Author
01 May 2019 14:28 #132439
by marq_torque
About Spindle Acceleration Deceleration Ramp was created by marq_torque
Hello Everyone,
I am configuring C axis in lathe with Servo Spindle, i have used high power 3KW servo motor for main drive which will run Speed and Position mode
By default it will stay in position mode, as soon as it receives M3/M4 output it switches to Speed mode and works as normal lathe spindle and when M5 is issued that output will be off, so servo will locking immediately without any smooth deceleration, so that is the problem it will obviously jerk and trigger over load error.
I am looking for smooth ramp for spindle start up and slow down, i have setup similar in Mach3 it was having those spindle on off delay so it was working normal.
Any workout on this available ?? i looked into but found no parameters for Spindle acceleration/deceleration.
Thanks,
Ankit
Thanks,
Ankit
- marq_torque
- Topic Author
01 May 2019 14:33 #132440
by marq_torque
Replied by marq_torque on topic About Spindle Acceleration Deceleration Ramp
I am currently using 0-10V PWM to analog output via on board par port.
01 May 2019 16:27 - 01 May 2019 18:19 #132448
Replied by PCW on topic About Spindle Acceleration Deceleration Ramp
This is often done by using the limit3 component to bound the acceleration of the commanded spindle speed
loadrt limit3
addf limit3.0 servo-thread
setp limit3.0.maxv 250 # 250 RPM/second
setp limit3.0.enable true
net your_commanded_spindle_speed_signal => limit3.0.in
net your_analog_spindle_command <= limit3.0.out
loadrt limit3
Last edit: 01 May 2019 18:19 by PCW. Reason: fix pin name
The following user(s) said Thank You: marq_torque
- marq_torque
- Topic Author
03 May 2019 04:53 #132599
by marq_torque
Much Thanks for input,
Does this works for deceleration also ??
Regards,
Ankit
Regards,
Ankit
03 May 2019 06:26 #132603
by pl7i92
Replied by pl7i92 on topic About Spindle Acceleration Deceleration Ramp
if you are not in safty concern or tool Change need just let it run out the 10seconds it needs
it will give you a very long live
07 Dec 2023 19:08 #287474
by COFHAL
Replied by COFHAL on topic About Spindle Acceleration Deceleration Ramp
I have a test configuration with two spindles commanded with PWM, on a MESA 7i96s card.
I'm having this problem using Soft Start with the limit3 component with the spindle. Without using Soft Start the spindle output is connected to spindle-output <= pid.s.output, but if I activate Soft Start using limit3, I necessarily have to comment pindle-output <= pid.s.output or else it doesn't give me a mistake. How could I continue pid.s.output without getting the error? When commenting spindle-output <= pid.s.output, the Soft Start works but not very well in the sense that when I stop the spindle com M5 and activate the spindle again, the Soft Start does not work and the spindle starts all at once the commanded speed. This does not happen when I do not use limit3 and the output of spindle is connected to pid.s.output, I think the problem is that the output of the splitdle does not go through pid.s.output, but I don't know how to solve it.
And a final question, the Soft Start works very well when starting the spindle but when the order is given to stop it does not do so in a Soft End way, but rather it stops abruptly.
Is there a way to make the stop also be in the form of a ramp?
I attach my HAL files. and INI
07 Dec 2023 21:23 #287483
If you wish to use the output of the PID to run the spindle,
you would need a bit of rewiring (changes with **** in comment)
Also you cannot use spindle enable to enable the PWMgen
as it is forced to false whenever the spindle speed is set to 0
bypassing the limit3 decceleration.
# SPINDLE 0
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable => pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net raw-spindle-output <= pid.s.output # **** before limit3
# ---PWM Generator signals/setup---
setp hm2_7i96s.0.pwmgen.00.output-type 1
setp hm2_7i96s.0.pwmgen.00.scale [SPINDLE_0]OUTPUT_SCALE
#setp hm2_7i96s.0.gpio.033.invert_output true
net spindle-output => hm2_7i96s.0.pwmgen.00.value
net machine-on => hm2_7i96s.0.pwmgen.00.enable # **** must not turn off at 0 speed or limit3 will not work
# ARRANQUE SUAVE DEL SPINDLE 0 CON RAMPA
setp limit3.spindle0.maxv 100 # 100 RPM/second VARIANDO ESTE VALOR LA RAMPA SE HACE MAS PLANA O MAS PRONUNCIADA PARA ALCANZAR LA VELOCIDAD COMANDADA
setp limit3.spindle0.maxa 1000
setp limit3.spindle0.enable true
net raw-spindle-output => limit3.spindle0.in # **** from PID
net spindle-output <= limit3.spindle0.out
# SPINDLE 0
- Thank you received: 5944
07 Dec 2023 22:24 #287489
Replied by tommylight on topic About Spindle Acceleration Deceleration Ramp
This topic is over 4 years old.
07 Dec 2023 23:06 #287497
Last post was today and same subject...
