Is there a Halpin for the current feedrate
07 Jun 2020 11:50 #170468 by Aciera
Have you looked at these with the HAL scope?
07 Jun 2020 12:03 #170470 by dgarrett
A patch to add pin motion.feed-upm:
github.com/LinuxCNC/linuxcnc/commit/772c...98162ba56639d231311f
I won't commit until #865 is fixed;
github.com/LinuxCNC/linuxcnc/issues/865
Using the master branch with this defect is hazardous:
forum.linuxcnc.org/38-general-linuxcnc-q...tton-pressed-in-axis
07 Jun 2020 12:51 - 07 Jun 2020 12:53 #170472 by rodw
Dewey, Awesome, thanks very much. I tried doing that today but got tangled up with the pointers. Anyway, at least I know I was on the right track!
If you wanted another challenge, adding another tag for arc radius would be much appreciated. I did find the radius was calculated in interp_arc.cc but knew it would be a hard slog to learn how to follow it through.
I was thinking something like this would do the trick!
tag.fields_float[GM_FIELD_FLOAT_RADIUS]
This is the other variable I'd like becasue the two together would let us do funky stuff to improve hole cut quality with plasma cutting in hal
Last edit: 07 Jun 2020 12:53 by rodw.
Time to create page: 0.099 seconds
