Spindle brake delay vs E-Stop
09 Jun 2020 20:41 #170865
by Tom_R2E3
Spindle brake delay vs E-Stop was created by Tom_R2E3
Hopefully this hasn't been asked before...
My Mill has a spindle brake. I would like to have a delay to the activation of the brake when I stop the spindle, UNLESS I have activated E-stop. Is there a simple way to set this up in the HAL file?
This is my spindle brake section at the moment:
So at the moment I have a second delay for the spindle brake in all conditions.
Thanks in advance,
Tom
# -------------------------- SPINDLE BRAKE ------------------------------------
# Intended operation: motion.spindle-brake controls the brake UNLESS the button connected to input-10 is held down
loadrt timedelay count=1
addf timedelay.0 servo-thread
net spindle-brake xor2.0.in0 <= motion.spindle-brake
net spindle-brake-button xor2.0.in1 <= hm2_5i25.0.7i77.0.0.input-10
setp hm2_5i25.0.7i77.0.0.output-00-invert 1
net spindle-brake-both xor2.0.out => timedelay.0.in
net spindle-delayed timedelay.0.out => hm2_5i25.0.7i77.0.0.output-00
setp timedelay.0.on-delay 5
setp timedelay.0.off-delay 0
Thanks in advance,
Tom
- Thank you received: 5983
09 Jun 2020 21:12 #170877
Replied by tommylight on topic Spindle brake delay vs E-Stop
Using inverted spindle-on pin might have been easier and better, in my opinion.
Adding a timedelay when stopping the spindle and adding AND to e-stop out, so the brake will be delayed when stopping it normally and would engage immediately on E-stop.
Something like:
Something like:
spin-on>invert>timedelay>
------------------------------------|and >brake
estop>>>>>>>>>>>>>>>>
09 Jun 2020 21:57 - 09 Jun 2020 22:03 #170883
by alkabal
Replied by alkabal on topic Spindle brake delay vs E-Stop
I have do something similar with enable signal that work fine i think you can check and adapt for brake.
Br
forum.linuxcnc.org/10-advanced-configura...le-soft-stop?start=0
Br
# timedelay before disable enable output for ramp the brake
loadrt timedelay names=timedelay.spindle-enable-soft-stop
addf timedelay.spindle-enable-soft-stop servo-thread
setp timedelay.spindle-enable-soft-stop.on-delay 0
setp timedelay.spindle-enable-soft-stop.off-delay 0.85
net spindle-enable <= spindle.0.on
net spindle-enable => timedelay.spindle-enable-soft-stop.in
net spindle-enable-soft-stop <= timedelay.spindle-enable-soft-stop.out
net spindle-enable-soft-stop => pid.spindle.enable
net spindle-enable-soft-stop => [HMOT](CARD0).7i83.0.0.analogena0
Last edit: 09 Jun 2020 22:03 by alkabal.
10 Jun 2020 06:38 #170915
by bbsr_5a
Replied by bbsr_5a on topic Spindle brake delay vs E-Stop
cand you use a simple ramp UP and Ramp down
linuxcnc.org/docs/html/examples/spindle....#_spindle_soft_start
