- Configuring LinuxCNC
- HAL
- Suddenly my config doesn't work - configured in PnCConf, but error showing HAL
- B.Reilly01
- Thank you received: 13
27 Jun 2020 02:18 #172826
by B.Reilly01
Suddenly my config doesn't work - configured in PnCConf, but error showing HAL was created by B.Reilly01
So I've been running a config configured in pncconf for a while. Recently it stopped working, and the error I'm getting is at load. Axis will not load the error is:
Debug file information:
./Hurco_SM1_052520-new_motor.hal:37: Pin 'hm2_5i25.0.7i77.0.0.output-13' does not exist
3599
Stopping realtime threads
Unloading hal components
I thought this might be a HAL problem. Output 13 is spindle CCW... I don't know much about HAL, but if I can get any help, it would be appreciated. Thank you.
3599
27 Jun 2020 06:54 #172840
by Clive S
it is always a good idea to post the hal and ini files from your "machine name" in the config folder
Replied by Clive S on topic Suddenly my config doesn't work - configured in PnCConf, but error showing HAL
3599
- Thank you received: 5983
27 Jun 2020 11:25 #172848
Replied by tommylight on topic Suddenly my config doesn't work - configured in PnCConf, but error showing HAL
There is no field power going to the 7i77.Debug file information:
3599
- B.Reilly01
27 Jun 2020 17:30 #172883
by B.Reilly01
Replied by B.Reilly01 on topic Suddenly my config doesn't work - configured in PnCConf, but error showing HAL
Thank you, it was field power. I had been having problems with the 5i25 dropping out mid operation and had taken the PC out to clean the contacts and forgot to plug in the field power connector.
- HAL
Time to create page: 0.120 seconds
