Using Debounce
16 Jul 2020 07:16 #174808
by Clive S
Using Debounce was created by Clive S
What is the correct procedure to use "debounce" on a switch or sensor.
Re this:-
loadrt debounce cfg=1
addf debounce.0 servo-thread
setp debounce.0.delay 100
net homes-x < =parport.0.pin-12-in-not
net homes-x => debounce.0.0.in
I think the above is correct but when would you use a debounce.0.0.out pin and how?
Re this:-
16 Jul 2020 08:05 - 16 Jul 2020 08:12 #174810
Replied by Aciera on topic Using Debounce
Debouncing explained:
www.labbookpages.co.uk/electronics/debounce.html
[edit]
Basically you require debouncing whenever your signal does not change state in a stable manner. e.g. a mechanical contact. Sensors often have a hysteresis built in so bouncing is avoided.
In your example parport.0.pin-12-in-not is the bouncing input and debounce.0.0.out would be the debounced signal you would acually use.
[edit]
Last edit: 16 Jul 2020 08:12 by Aciera.
16 Jul 2020 08:47 #174817
by Clive S
Butl in my PlasmaC config i have this as an example.
net plasmac:float-switch hm2_7i96.0.gpio.003.in => debounce.0.0.in
But there are no debounce out pins. This is the bit I don't understand.
Replied by Clive S on topic Using Debounce
I understand what debounce mean in the context of switchesDebouncing explained:
[edit]
16 Jul 2020 10:03 #174823
by phillc54
Replied by phillc54 on topic Using Debounce
The debounce out pins are used in the plasmac.tcl file
16 Jul 2020 14:31 #174851
by Clive S
So to use debounce would this be correct:-
net home-x < = parport.0.pin-12-in-not switch or sensor
net home-x = > debounce.0.0.in
net home-x-out <= debounce.0.0.out or am I missing something here
16 Jul 2020 23:05 #174891
by phillc54
You would need to finish it off with something like:
net home-x-out => joint.0.home−sw−in
Time to create page: 0.078 seconds
