(solved) Hal pin for spindle has stopped
10 Aug 2020 14:20 - 10 Aug 2020 19:42 #177816
by anfänger
(solved) Hal pin for spindle has stopped was created by anfänger
Hello,
I have a question is there a pin which shows the spindle is in motion or stopped?
At the moment when estop is triggered I also cut all the power to the drives (This happens in Ladder).
But then the spindle slowly running down, So I want to delay this until the spindle has stoped.
I wonder what is the best solution for this is there already I pin I can use? O so I use „near“ like for spindle at speed?
Or is there even a better solution in total?
Thanks Patrick
Thanks Patrick
Last edit: 10 Aug 2020 19:42 by anfänger.
10 Aug 2020 15:00 #177820
Replied by PCW on topic Hal pin for spindle has stopped
I would use "near" but I would not want to delay axis motion shutdown
waiting for the spindle to stop.
10 Aug 2020 15:03 #177821
by Grotius
Replied by Grotius on topic Hal pin for spindle has stopped
This is good.
But then the spindle slowly running down.
If your spindle drive or frequency regulator has a brake. Then try to activate the brake when estop is triggered.
You problably want to do this, because your drive get's in error?
This is good.
10 Aug 2020 15:09 #177822
by anfänger
Replied by anfänger on topic Hal pin for spindle has stopped
At the moment spindle and drives are wired together (was already done this way with the old controller). I could split them cause there a enough io left. But doesn’t linuxcnc stop all motion when in estop? I just want to cut the power to the dives a bit later.
10 Aug 2020 19:41 #177836
by anfänger
Near works i use it with a latch to prevent restart for whatever reason.
now I works perfectly. thanks for the help
cheers Patrick
cheers Patrick
Time to create page: 0.119 seconds
