userspace module wont load from hal file
30 Aug 2020 03:34 - 30 Aug 2020 03:37 #180010
by JR1050
userspace module wont load from hal file was created by JR1050
Im having an odd issue with loading a userspace module. The comp is for the Pokeys board. The component will load from the terminal and run, it shows its pins with the show pins command, if I load it from the terminal and then load lcnc or just load lcnc ,lcnc loads, the component comes alive and i can see its inputs change state when triggered. If i try to load it from a lcnc from the gui , I get an error message "pokeys.0.devSerial does not exist". Im loading the component like so from both the hal file and the terminal;
loadusr pokeys
setp pokeys.0.devSerial 11610
i have also tried
loadusr pokeys -W
version is lcnc 2.7.14 on stretch. I also have horrible latency and a real time error when lcnc loads, mother board is an intel atom with the hyperthreading deactivated suggestions?
loadusr pokeys
i have also tried
loadusr pokeys -W
Last edit: 30 Aug 2020 03:37 by JR1050.
30 Aug 2020 03:40 #180013
Replied by rodw on topic userspace module wont load from hal file
try loading and configuring your component in the postgui hal file
Time to create page: 0.120 seconds
