Trouble after new installation
10 Sep 2020 12:39 #181619
by Stran_ge
Replied by Stran_ge on topic Trouble after new installation
unfortunately that didnt help either.
Dont know if mentioned it earlier im on Linuxcnc 2.7
www.linuxcnc.org/testing-stretch-rtpreempt/ is what i am running.
10 Sep 2020 12:55 #181623
Replied by Aciera on topic Trouble after new installation
Ah, I thought you were on 2.8 because you have axis and joint entries in your ini. I think 2.8 would be a much better choice for a gantry.
10 Sep 2020 13:02 #181625
by Stran_ge
im kinda scared having to do all my configs again tho...
10 Sep 2020 13:19 #181627
I hear ya.
But if you save your current config and use the package manager to update linuxCNC to 2.8 and give it a try? You could always downgrade again and continue where you're at now.
And I really think 2.8 is the place to be.
The following user(s) said Thank You: Stran_ge
10 Sep 2020 13:22 #181629
by Stran_ge
I will try that!
I'll report back.
I'll report back.
10 Sep 2020 13:58 #181633
by Stran_ge
so your tip was gold, i upgraded to 2.8 and now everything is working again without changing anything in the configuration.
Just one tiny thing isnt working as expected now, pre 2.8 upgrade my xhc-whb04b-6 worked perfect. halrun: loadusr xhc-whb04b-6 gave out reactions for every button on the handwheel.
Now it isnt't working anymore, i had to disable basically everything in my xhc-whb04b-6.hal to get Linuxcnc to start.
Is there something that has to be updated or maybe re-compiled after a linuxcnc upgrade to 2.8 ?
Anyway,
thank you so mutch!
Nils
Anyway,
thank you so mutch!
Nils
10 Sep 2020 14:12 - 10 Sep 2020 14:13 #181636
There are a few threads about that in the forum if you search for xhc-whb04b-6. I'm afraid I can't give you any advice there.
linuxcnc.org/docs/2.8/html/man/man1/xhc-whb04b-6.1.html
Last edit: 10 Sep 2020 14:13 by Aciera. Reason: Added link
10 Sep 2020 15:16 #181645
by Stran_ge
I just got the handwheel working aswell. Just had to re-compile the driver and everything worked!
10 Sep 2020 15:18 #181646
Awesome, glad to hear it.
Time to create page: 0.171 seconds
