Developing HAL component in c
17 Oct 2020 11:01 - 17 Oct 2020 11:03 #186347
by MasterTom
Developing HAL component in c was created by MasterTom
I started a simple component: tomtom.c
I tested it with: halcmd loadrt tomtom
I got:
Waiting for component 'tomtom' to become ready..Waited 3 seconds for master. giving up.
Note: Using POSIX realtime ..........................................................................................................................................
According to existing components in linuxcnc-dev/src/hal/components I created the following code:
With this code I get additional prints
> STEP 1
> STEP export pins
> DONE export pins
> STEP export hal_export_funct
> DONE export hal_export_funct
> CALL hal_ready
> DONE CALL hal_ready
==> rtapi_app_main was successfully finished.
What is the problem?
How to really debug such code?
I got:
> STEP 1
> STEP export pins
> DONE export pins
> CALL hal_ready
> DONE CALL hal_ready
#include "rtapi.h" /* RTAPI realtime OS API */
#include "rtapi_app.h" /* RTAPI realtime module decls */
#include "hal.h" /* HAL public API decls */
/* module information */
MODULE_AUTHOR("TomTom");
MODULE_DESCRIPTION("First Test");
MODULE_LICENSE("GPL");
typedef struct {
int counter_limit_top;
int counter_limit_bottom;
int increment;
hal_bit_t *up; /* true-->up false-->down*/
hal_bit_t *start; //true-->run false-->stop */
hal_s32_t *counter;
} hal_tomtom_t;
static hal_tomtom_t *p_tom_data;
static int comp_id; /* component ID */
static void tomtom_realtimefunction(void *arg, long period);
static int _counter_value;
int rtapi_app_main(void)
rtapi_print("--------------------------> STEP 1\n");
comp_id = hal_init("Tom Test");
if (comp_id < 0)
rtapi_print_msg(RTAPI_MSG_ERR,
"Tom Test: ERROR: hal_init() failed\n");
return -7;
p_tom_data = hal_malloc(sizeof(hal_tomtom_t));
if (p_tom_data == 0)
"Tom Test: ERROR: hal_malloc() for p_tom_dat \n");
hal_exit(comp_id);
hal_exit(comp_id);
return -11;
// init
p_tom_data->increment = 1;
p_tom_data->counter_limit_bottom = -100;
p_tom_data->counter_limit_top = 100;
// export pins
rtapi_print("--------------------------> STEP export pins\n");
int ret_val = hal_pin_bit_new("TomTomCounter.start/stop", HAL_IN, &(p_tom_data->start),comp_id);
if (ret_val != 0)
return -12;
rtapi_print("--------------------------> DONE export pins\n");
ret_val = hal_pin_s32_new("TomTomCounter.Counter", HAL_OUT,&(p_tom_data->counter),comp_id);
if (ret_val != 0)
return -14;
rtapi_print("--------------------------> STEP export hal_export_funct\n");
ret_val = hal_export_funct("Tom Tom",tomtom_realtimefunction, &p_tom_data, 0, 0,comp_id);
if (ret_val != 0)
"WEIGHTED_SUM: ERROR: group %d export failed\n");
hal_exit(comp_id);
return -15;
rtapi_print("--------------------------> DONE export hal_export_funct\n");
rtapi_print("--------------------------> CALL hal_ready\n");
hal_ready(comp_id);
rtapi_print("--------------------------> DONE CALL hal_ready\n");
return 0;
void rtapi_app_exit(void)
rtapi_print("--------------------------> EXIT called\n");
hal_exit(comp_id);
rtapi_print("-cyclic\n");
return;
p_tom_data = (hal_tomtom_t*)arg;
if (p_tom_data->start)
p_tom_data->counter++;
rtapi_print_msg(RTAPI_MSG_ERR, "Hallo");
Last edit: 17 Oct 2020 11:03 by MasterTom. Reason: Additional question
17 Oct 2020 12:06 #186351
by dgarrett
A likely cause:
The name of the component and the file name must agree.
Replied by dgarrett on topic Developing HAL component in c
A likely cause:
The following user(s) said Thank You: MasterTom
17 Oct 2020 12:55 #186352
by MasterTom
Replied by MasterTom on topic Developing HAL component in c
I'm sorry. I'm new to LinuxCNC.
Now it is working better.
But there is no call hal_export_funct.
What could be the problem?
Thanks Thomas
Thanks Thomas
17 Oct 2020 13:06 #186353
by dgarrett
suggest:
suggest:
//ret_val = hal_export_funct("Tom Tom",tomtom_realtimefunction, &p_tom_data, 0, 0,comp_id);
ret_val = hal_export_funct("tomfunc",tomtom_realtimefunction, p_tom_data, 0, 0,comp_id);
17 Oct 2020 13:23 #186356
by MasterTom
unfortunality it doesn't get cyclic:
these are what I got from halcmd;
tom@linuxcnc:/usr/lib/linuxcnc/modules$ halcmd -V loadrt tomtom
HAL: initializing hal_lib
HAL: initializing component 'halcmd5893'
HAL: component 'halcmd5893' initialized, ID = 10
HAL: removing component 10
HAL: releasing RTAPI resourcesHAL: component 10 removed, name = 'halcmd5893'
/usr/bin/rtapi_app load tomtom
smalloc_dn: shmem available 347760
HAL: component 'halcmd5893' initialized, ID = 02
> STEP 1
> STEP export pins
> DONE export pins
> CALL hal_ready
> DONE CALL hal_ready
<commandline>:0: Component 'tomtom' ready
<commandline>:0: Program '/usr/bin/rtapi_app' started
smalloc_up: shmem available 347047
<commandline>:0: Realtime module 'tomtom' loaded
HAL: removing component 02
HAL: releasing RTAPI resourcesHAL: component 02 removed, name = 'halcmd5893'
> STEP 1
> STEP export pins
> DONE export pins
> CALL hal_ready
> DONE CALL hal_ready
17 Oct 2020 13:41 #186359
by dgarrett
try:
Note: during debugging,if hal exits abnormally you
may need to issue $ halrun -U
try:
$ cat tst.hal # create this file
# (adjust component and funct names as reqd)
loadrt tomtest
loadrt threads name1=t period1=25000 period2=1000000
addf tomfunc t
start
$ halrun tst.hal
17 Oct 2020 15:34 #186366
by MasterTom
thanks for your great support. My component is working now (also under linuxcnc)
Best reagrds Thomas
Best reagrds Thomas
Time to create page: 0.231 seconds
