Linux parallel port @35840 not found
26 Oct 2020 00:50 #187261
by hoffeys
Linux parallel port @35840 not found was created by hoffeys
Not sure if this is the right forum to post this. I set Parallel Port 1 in stepconf to 0x8C00 and I'm able to get the X Y Z motors to react when I test them. When I try a test run with the sample file I get this error. I don't know why it is looking for 35840 when I set it in stepconf to the correct address and it works there. All I could find online was a reference to setting loadrt hal_parport cfg="XxXXXX" in my hal file. When I look in my .hal file the port is correctly set to "0x8c00 out" but I still get the "port not found" error when loading up the sample file.
Background: A woodworker friend of mine was given a custom built cnc router without any software or computer from an acquaintance that had brain surgery and "can't remember how it works" after the surgery. I set up a Linux PC with an addon PCI parallel port and LinuxCNC but this is as far as I've been able to get.
Here is a link to an album with photos of the setup and error message. Thanks for any help!
- BeagleBrainz
- User is blocked
- Thank you received: 570
26 Oct 2020 02:32 #187267
by BeagleBrainz
Replied by BeagleBrainz on topic Linux parallel port @35840 not found
The bigger problem is the latency issue. Have you run a latency test on the PC.
26 Oct 2020 03:18 #187269
by hoffeys
Replied by hoffeys on topic Linux parallel port @35840 not found
Yes, it passed the latency test fine.
- BeagleBrainz
- User is blocked
26 Oct 2020 03:35 #187271
by BeagleBrainz
Oh ok.
Can you attach your hal & ini files ? Then run the following and post any output relating to the parallel port.
lspci -vn
Time to create page: 0.123 seconds
