FASTIO
18 Jan 2021 05:49 #195752
by tjtr33
Hal_parport has a note about FASTIO
/* If FASTIO is defined, uses outb() and inb() from <asm.io>,
instead of rtapi_outb() and rtapi_inb() - the <asm.io> ones
are inlined, and save a microsecond or two (on my 233MHz box)
I searched around and saw this FASTIO mentioned and enabled in several drivers.
it is NOT in a file name asm.io ( doesnt exist)
there IS an asm/io.h
BUT the macros (inline) seem to be in rtapi_parport.h
the CODE between the triple quotes could be inserted into hal_parport to try
(my intenet is to rewrite hal_pi_gpio to allow invert and reset pins,
so I study all the current techniques to enumrate and store pins & states)
This FASTIO could allow faster threads or reduce UXRTdelays
(UnexpectedRealtimeDelays)
(JMKasunich)
(usage)
#define FASTIO
#ifdef FASTIO
#define rtapi_inb inb
#define rtapi_outb outb
#include <asm/io.h>
#endif
This 'usage' seems to contradict the original notes.
Has anyone tried FASTIO ( used an assembler macro to speed up byte sized reads and writes? )
and
There is no <asm.io> so where are these macros?
TomP
(JMKasunich)
(usage)
#define FASTIO
#ifdef FASTIO
#include <asm/io.h>
#endif
and
TomP
19 Jan 2021 12:43 #195882
As this is J M Kasunich, and he is talking about a 233MHz PC I think that this is very old information. Possibly 20 years old.
I am pretty sure that the note is referring to <asm/io.h> as that is where inb and outb are defined.
github.com/torvalds/linux/blob/master/arch/x86/include/asm/io.h
I even think that this note might date from when LinuxCNC was compiled-to-suit, ie before JMK invented HAL.
Current code should _not_ use inb and outb as the ability to use both kernel and uspace modes depends on the abstraction in rtapi.
