qHalView
22 Jan 2021 21:40 #196283
by fixer
As a simple exercise in QT and Python, I made a simple "live" HAL file viewer. It loads hal file in an listview and reads signal values from running instance of LinuxCNC. Similar functionality as "halshow".
Maybe someone finds it useful
github
To do:
interactive set_phttp://linuxcnc.org/docs/2.8/html/hal/halmodule.html#_set_p with mouse...
github
To do:
The following user(s) said Thank You: tommylight, smandyscom
- Thank you received: 5944
22 Jan 2021 21:50 #196286
That is on Mint 20 where python3 reigns supreme despite having 5 or more other versions of python installed so almost everything using QT5 fails to run.
Will test on Mint 19.3 where QT5 runs nicely when i get a chance.
Replied by tommylight on topic qHalView
cnc@X570:~/Downloads/linuxcnc_stuff/tmp/qHalView-main$ python qHalView.py
File "qHalView.py", line 7, in <module>
from PyQt5.QtCore import *
ImportError: No module named QtCore
cnc@X570:~/Downloads/linuxcnc_stuff/tmp/qHalView-main$ python3 qHalView.py
File "qHalView.py", line 12, in <module>
import hal, time
ModuleNotFoundError: No module named 'hal'
22 Jan 2021 22:22 #196290
by fixer
- smandyscom
24 Jun 2021 01:01 #212773
by smandyscom
Replied by smandyscom on topic qHalView
hi fixer, your demo is precious!
I learn from it that global read_value() should go after created a costumed component, which is pretty tricky.
however as my limited knowing to PyQt5, isn't it only supporting under Python3?
I cannot figure out how it can work to combine HAL in python2 with PyQT5 in python3.
Time to create page: 0.094 seconds
