New component for keyboards and panels.
A poor quality video proving that it works:
It can take either 7i73-style scancodes from a 7i73 or from matrix_kb, and can also generate key events from plain bit HAL pins.
Intended for MDI keyboards and GUI interaction. Use to control actual machine movements is very much discouraged.
- BeagleBrainz
- User is blocked
- Thank you received: 570
Roughly speaking, not yet looked at code, this is "stuffing" scan codes into the OS ?
Not exactly. The HAL component tells the system that it is a USB keyboard, "and here are some key events"
- BeagleBrainz
- User is blocked
That's pretty cool.
In the man page, this link is not working for me though:
wiki.linuxcnc.org/cgi−bin/wiki.pl?Scancodes
And thanks for sharing this!
- Thank you received: 5944
Still 404.In the man page, this link is not working for me though:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Scancodes
Looks like an issue with hyphens.
It's an ASCII 2D minus sign in the source code.
I need to se how to force asciidoc to not convert to hyphen.
And the URL is fine in the html docs generated on my test machine too!
I am a bit stumped.
Exactly the hyphen in the link I posted is a bit longer then in the one you posted.
This seems to be the same issue that has come up a few times when people copy/paste HAL pin names from man pages into their HAL files and the pin names are not recognized because the hyphen is a bit longer. I wonder if it depends on the users PC though because I'm sure a lot of people do that and the issue does not come up very often in the forum.
How can there be two different hyphens?
ASCII code 45 = - ( Hyphen , minus sign )
The only other similar symbol I see is this. But it seems much longer.
ASCII code 196 = ─ ( Box drawing character single horizontal line )
[edit]
Ok, wikipedia just told me that in unicode there are a few different symbols:
There are at least eight different horizontal dash-like characters of varying lengths defined in Unicode
