Debounce
06 Mar 2021 16:17 #201196 by madguernseyboy
Debounce was created by madguernseyboy
Good day
Can someone help implement the debounce on my HAL file for the 3 home switches.
Just not sure how its supposed to be.
Thank you
Brendan
06 Mar 2021 21:00 #201214 by madguernseyboy
Replied by madguernseyboy on topic Debounce
I found the solution.
Add these lines at the top
# add debounce component
loadrt debounce cfg=3
# set delay (number of iterations of base thread )
setp debounce.0.delay 200
# add debounce to thread
addf debounce.0 base-thread
Replace the these three lines
net both-home-x <= parport.0.pin-10-in
net both-home-y <= parport.0.pin-11-in
net min-home-z <= parport.0.pin-12-in
Replace with this
net debounce-home-x debounce.0.0.in <= parport.0.pin-10-in
net both-home-x debounce.0.0.out
net debounce-home-y debounce.0.1.in <= parport.0.pin-11-in
net both-home-y debounce.0.1.out
net debounce-home-z debounce.0.2.in <= parport.0.pin-12-in
net min-home-z debounce.0.2.out
I hope this helps someone else.
Brendan
The following user(s) said Thank You: andypugh
07 Mar 2021 04:05 #201259 by phillc54
Replied by phillc54 on topic Debounce
If you use 2.8 or later it is worth considering the dbounce component which allows naming
Time to create page: 0.588 seconds
