loading similar components in main and custom HAL files
- ExcessiveO
- Thank you received: 5
10 Jun 2021 21:51 #211738
by ExcessiveO
can you load a component(specifically a scale component) and use it in the main hal file, then load a separate component that is the same type into the custom hal file? I tried doing this and get an error saying "scale.ko: File Exists"
- Thank you received: 5945
10 Jun 2021 23:05 #211753
Replied by tommylight on topic loading similar components in main and custom HAL files
Not sure if it works but using "twopass" might help:
linuxcnc.org/docs/html/hal/twopass.html
www.google.com/search?q=twopass+site%3Al...TyCI4Q4dUDCAY&uact=5
Time to create page: 0.207 seconds
