PID feedback derivative
05 Aug 2021 15:48 #216989
by bierluiz
PID feedback derivative was created by bierluiz
Hello,
I would like to sample the pin pid.N.feedback-deriv, but it is an input pin. Is there a way to do it?
Also, from the PID page: "If no signal is connected then the derivative will be estimated numerically". Where can I access this information? Is there a way to change/copy its value to an output pin?
Thank you.
Thank you.
05 Aug 2021 23:32 #217014
Replied by andypugh on topic PID feedback derivative
You should be able to get the same numerical value by using the "ddt" hal component on the feedback value.
github.com/LinuxCNC/linuxcnc/blob/master...omponents/pid.c#L376
The following user(s) said Thank You: bierluiz
Time to create page: 0.094 seconds
