Dual joints same axis - PROBLEMS
- Schneiderman
01 Sep 2021 16:52 #219353
by Schneiderman
Dual joints same axis - PROBLEMS was created by Schneiderman
Hi!
I am trying to add a new joint to my gantry cnc (XYZ)
I am not getting any errors, but the the second motor on the Z axis does not move at all!
I already checked the wiring, and the second motor is wired correctly, I have already tested it using the stepwizard.
Could somebody help me with this issue?
I will copy/paste the ini and hal files here.
Thank you in advance!
**************************************************************INI FILE*************************************************************************
# Generated by stepconf 1.1 at Tue Aug 31 07:50:34 2021
# overwritten when you run stepconf again
[EMC]
MACHINE = reducoes_diferentes
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 2.50
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 25.00
INTRO_TIME = 5
PROGRAM_PREFIX = /home/michel/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYZZ
[FILTER]
PROGRAM_EXTENSION = .nc,.tap G-Code File
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALFILE = reducoes_diferentes.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 23.75
MAX_ACCELERATION = 1.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
STEPGEN_MAXACCEL = 1.25
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
[AXIS_Y]
MAX_ACCELERATION = 750.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
STEPGEN_MAXACCEL = 937.5
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
[AXIS_Z]
MIN_LIMIT = -100.0
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.001
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.001
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
**************************************************************HAL FILE*************************************************************************
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0x1110 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0,0
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net z0step => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net z0dir => parport.0.pin-07-out
net z1step => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
net z1dir => parport.0.pin-09-out
net xenable => parport.0.pin-14-out
net min-x <= parport.0.pin-10-in-not
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 20000
setp stepgen.0.dirsetup 20000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
net min-x => joint.0.neg-lim-sw-in
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 20000
setp stepgen.1.dirsetup 20000
setp stepgen.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 20000
setp stepgen.2.dirsetup 20000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net z0pos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net z0pos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net z0step <= stepgen.2.step
net z0dir <= stepgen.2.dir
net z0enable joint.2.amp-enable-out => stepgen.2.enable
setp stepgen.3.position-scale [JOINT_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 20000
setp stepgen.3.dirsetup 20000
setp stepgen.3.maxaccel [JOINT_3]STEPGEN_MAXACCEL
net z1pos-cmd joint.3.motor-pos-cmd => stepgen.3.position-cmd
net z1pos-fb stepgen.3.position-fb => joint.3.motor-pos-fb
net z1step <= stepgen.3.step
net z1dir <= stepgen.3.dir
net z1enable joint.3.amp-enable-out => stepgen.3.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
[EMC]
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
ARCDIVISION = 64
INTRO_TIME = 5
[KINS]
JOINTS = 4
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
[HAL]
[TRAJ]
COORDINATES = X Y Z
LINEAR_UNITS = mm
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_X]
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
[AXIS_Y]
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 200.0
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
[AXIS_Z]
MIN_LIMIT = -100.0
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.001
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.001
SCALE = 400.0
FERROR = 1
MIN_FERROR = .25
HOME_OFFSET = 0.0
02 Sep 2021 23:21 #219469
Replied by andypugh on topic Dual joints same axis - PROBLEMS
How are you trying to move the axes? I don't see any jog controls set up, nor do I see any home sequence.
So, are you perhaps still in "joint mode" ?
Which UI are you using?
Time to create page: 0.287 seconds
