compiling custom component LCNC2.7.15
04 Sep 2021 04:45 #219575
by Sourabh3
compiling custom component LCNC2.7.15 was created by Sourabh3
So i'm trying to compile a custom component for my automatic gearbox of maho mh1000T. i borrowed the component from ere:
github.com/jin-eld/mh400e-linuxcnc
I followed the steps given in here but couldn't succeed. So i looked up for the solution and found out this component was written for LCNC 2.7.14. And now the way to compile has been changed in the 2.7.15 version. I jumped to the documentation page of LCNC and found that the documents haven't been updated (i guess). because it says "Place the .comp file in the source directory linuxcnc/src/hal/components and re-run make. Comp files are automatically detected by the build system.If a .comp file is a driver for hardware, it may be placed in linuxcnc/src/hal/drivers and will be built unless LinuxCNC is configured as a userspace simulator."
But my linuxcnc folder doesn't contain any folder named as src. Can anyone help me to compile this component?
- Thank you received: 5970
04 Sep 2021 13:00 #219599
Replied by tommylight on topic compiling custom component LCNC2.7.15
In a terminal, CD to the folder containing the copm, then:
sudo halcompile -- install mh400e_gearbox.comp
that should also install it so no need to copy anything.
06 Sep 2021 05:27 #219719
by Sourabh3
Replied by Sourabh3 on topic compiling custom component LCNC2.7.15
I did that but nothing happened.
Also i encountered another problem. I am unable to run g33 cycle even in the below program, the machine becomes stationary and nothing happens, spindle rotates, machine moves to desired position but as soon as g33 line pops up, the machine becomes stationary. This is the program :
G90 (set absolute mode)
G0 X1.000 Y1.000 Z0.100 (rapid move to starting position)
S100 M3 (turn on the spindle, 100 RPM)
G33.1 Z-0.750 K0.05 (rigid tap a 20 TPI thread 0.750 deep)
M2 (end program)
M2 (end program)
06 Sep 2021 05:51 #219720
Replied by Aciera on topic compiling custom component LCNC2.7.15
You didn't get any feedback in the terminal?I did that but nothing happened.
Are you sure your spindle feedback (ie encoder input) is working properly?as soon as g33 line pops up, the machine becomes stationary
06 Sep 2021 06:24 #219723
by Sourabh3
I got the feedback in the terminal, with lots of warnings but no errors. I'll post the output as soon as i reach home.
I feel so dumb about g33 question right now. I thought only g33.1 needs Encoder not g33. Is there any way to use tapping cycle without Encoder? I will order a Encoder tonight. 500 ppr will be enough?
06 Sep 2021 07:33 #219734
If you get only warnings and no errors you should be fine. If the component loads without error in hal and all the appropriate hal pins are generated then I think halcompile worked.
I think 500 ppr should be ok.
12 Sep 2021 10:31 #220283
Replied by andypugh on topic compiling custom component LCNC2.7.15
The way to tell if a .comp has been successfully installed is if the final line in the output is "cp name-of-module /the/destination"
Time to create page: 0.078 seconds
