Servo-drive enable delay needed
02 Oct 2021 10:15 #222003
by Baderbahn
Servo-drive enable delay needed was created by Baderbahn
Hello guys,
after I got my encoders to work, I'm struggeling with the servo-enable timing.
I found, that as soon as I enable the machine in Gmoccapy, the servo-drives are also enabled. This particcular is a problem to me, due to the drive/ power/ E-Stop setup.
When the machine is shut on (by Gmoccapy), the servo-drives are powered up and need a few ms before they can accept the enable signal.
So I need a time delay between machine-is-enabled and servo-enable.
I've searched the forum a lot, but was unable to find anything that really fits and works propperly.
I was able to set up a delay between my mouse-click and the machine-enable GPIO-Output signal send to the machine, but not between Machine enable and drive enable.
Maybe you have an idea on how to solve this issue
Thanks and best regards,
Simon
Simon
02 Oct 2021 11:27 #222005
by anfänger
Replied by anfänger on topic Servo-drive enable delay needed
you can use a delay in ladder to solve this problem
02 Oct 2021 11:46 - 02 Oct 2021 11:49 #222006
by Baderbahn
Replied by Baderbahn on topic Servo-drive enable delay needed
Hello Anfänger,
I tried, but how ?
The problem is, that the drive-enable pin (TB5 NAN+ & NAN-) and the machine-is-on GPIO are switched simultaneously.
I can't find a way to delay the output on TB5
Edit: in my understanding, it doesn't matter, whether I program a delay by the timedelay- HAL function or by CL. My main problem is, how to decoupple machine-is-enabled and drive-enable.
regards,
Simon
I tried, but how ?
regards,
Simon
Last edit: 02 Oct 2021 11:49 by Baderbahn.
02 Oct 2021 13:38 #222013
Replied by Aciera on topic Servo-drive enable delay needed
Maybe post your hal file.
02 Oct 2021 13:49 - 02 Oct 2021 13:55 #222015
by Baderbahn
Yeah, I've found a way to delay the servo enable!
I added the following to my custom-hal
In the main hal-file, I disabled
sometimes, life can be so easy
loadrt timedelay
addf timedelay.0 servo-thread
setp timedelay.0.on-delay 0.5
net x-enable => timedelay.0.in
net x-enable-delay <= timedelay.0.out
net x-enable-delay => hm2_5i25.0.7i77.0.1.analogena
# enable _all_ sserial pwmgens
# net x-enable => hm2_5i25.0.7i77.0.1.analogena
Last edit: 02 Oct 2021 13:55 by Baderbahn.
- Thank you received: 5972
02 Oct 2021 15:14 #222022
Replied by tommylight on topic Servo-drive enable delay needed
That will also delay powering them down, so you might want to add an AND with
timedelay.0.out on one IN
and
x-enable on the other IN
while
hm2_5i25.0.7i77.0.1.analogena to AND OUT
and
while
02 Oct 2021 19:03 #222039
by Baderbahn
Hi Tommy,
good point!
I'll add this next time when I'm at the machine
regards,
Simon
good point!
regards,
Simon
Time to create page: 0.142 seconds
