Digital output reading and writing to led component
07 Oct 2021 08:57 #222433
by Leintz2
Digital output reading and writing to led component was created by Leintz2
Hi !
How to read mesa 7i76e digital output and turn on led in pyvcp?
so...I have ou digital output (hm2_7i76.0.7i76.0.0.output-02)...i want to read it an write its signal to pyvcp.led
Any ideas about the correct syntax?
Regards!
Regards!
07 Oct 2021 09:43 #222437
by MaHa
Replied by MaHa on topic Digital output reading and writing to led component
Example, in the vcp postgui.hal:
in .xml
net led-on-off pyvcp.ledonoff hm2_7i76.0.7i76.0.0.output-02
in .xml
<hbox>
<label text=""/>
<led><halpin>"ledonoff"</halpin><on_color>"Red3"</on_color><off_color>"gray86"</off_color><size>10</size></led>
<label><text>" Digital out"</text></label>
</hbox>
07 Oct 2021 11:06 #222447
by Leintz2
Replied by Leintz2 on topic Digital output reading and writing to led component
so...my version
custom_postgui.hal
net led_beaconred1 pyvcp.led_beaconred hm2_7i76e.0.7i76.0.0.output-02
pyvcp-panel.xml
<hbox>
<led>
<halpin>"led_beaconred"</halpin>
<size>18</size>
<on_color>"red"</on_color>
<off_color>"gray"</off_color>
</led>
<label>
<text>"Beacon RED (M111/M112)"</text>
<font>("Helvetica",10)</font>
</label>
</hbox>
I'm using M111 and M112 MDi commands to operate with this digital output...after adding those lines in custom_postgui.hal it disables M111 command in MDI mode and led on pyvcp panel does not react...
what is wrong?
custom_postgui.hal
pyvcp-panel.xml
<hbox>
<led>
<size>18</size>
</led>
<label>
</label>
</hbox>
what is wrong?
- Thank you received: 1370
07 Oct 2021 16:46 #222469
Replied by Todd Zuercher on topic Digital output reading and writing to led component
What do your M111 and M112 files look like?
08 Oct 2021 05:00 #222519
by Leintz2
M111 file:
#!/bin/bash
# beacon Red ON
halcmd setp hm2_7i76e.0.7i76.0.0.output-02 true
exit 0
M112 file:
#!/bin/bash
# beacon Red Off
halcmd setp hm2_7i76e.0.7i76.0.0.output-02 false
exit 0
#!/bin/bash
# beacon Red ON
exit 0
M112 file:
#!/bin/bash
# beacon Red Off
exit 0
08 Oct 2021 05:31 #222521
by MaHa
Can you try this in custom_postgui.hal
net led_beaconred1 hm2_7i76e.0.7i76.0.0.output-02
08 Oct 2021 06:14 #222523
by Leintz2
so ...no good result..hal_meter show me: led_beaconred1 FALSE all the time..and digital output DO-02 (commands -M111/M112) do not respond any more
08 Oct 2021 11:22 #222542
by Leintz2
ok...if I put lines to M111 file
#!/bin/bash
# vilkur Red ON
halcmd net led_beaconred1 hm2_7i76e.0.7i76.0.0.output-02
halcmd net led_beaconred1 pyvcp.led_beaconred
exit 0
it will turn on led (pyvcp panel)
but I cant turn it off with M112 command
M112 file:
#!/bin/bash
# vilkur Red OFF
exit 0
#!/bin/bash
# vilkur Red ON
exit 0
M112 file:
#!/bin/bash
# vilkur Red OFF
exit 0
08 Oct 2021 11:40 #222543
by Leintz2
so just hacking in different way:
add 2 lines to:
M111 file
halcmd setp pyvcp.led_beaconred true
M112 file
halcmd setp pyvcp.led_beaconred false
now it works
add 2 lines to:
M111 file
M112 file
now it works
08 Oct 2021 13:56 - 08 Oct 2021 14:00 #222551
The reason it didn't work before was because it is not possible to setp the value of a hal pin when it is connected to a signal. So when you created the hal line "net led_beaconred1 pyvcp.led_beaconred hm2_7i76e.0.7i76.0.0.output-02" linking both pins to the signal "led_beaconred1" it broke your custom M-codes.
As long as that signal isn't connected to a hal ouput pin you could have made it work by simply changing your M-code to use a sets command to set the signal true or false. (Keeping the "net led_beaconred1 pyvcp.led_beaconred hm2_7i76e.0.7i76.0.0.output-02" line of hal code.)[/code]
M111 file:
#!/bin/bash
# beacon Red ON
halcmd sets led_beaconred true
exit 0
and
[code]M112 file:
#!/bin/bash
# beacon Red Off
halcmd sets led_beaconred false
exit 0
Last edit: 08 Oct 2021 14:00 by Todd Zuercher.
