Zero axis with handwheel (w/o WCS) possible?
08 Oct 2021 01:03 #222507
by AkkiSan
Zero axis with handwheel (w/o WCS) possible? was created by AkkiSan
I recently bought one of those WHB04 handwheels and took the opportunity
to finally upgrade to 2.8, because almost everything seemed to be preconfigured.
I never ever touched any HAL files in the last two decades and managed to
keep things running by googling and browsing through this forum, but I'm
really stuck here and would appreciate any help.
Like every sane person, I usually use coordinate systems for any offsets
and I already managed to "program" the handwheel to do exactly that.
One machine though, a very big wood portal machine, cannot use WCSs
and also does not even have any limit switches.
What I need and failed to achieve is to somehow map the "home" or
"zero axis" function (the one usually executed by simply pressing the "home/pos1"
key) to the handwheel. My old control had keyboard support, so I could
simply map one of the keys to this functionality.
For this one here; close, but no cigar:
This just results in a "not possible in MDI mode" error.
Is there any way to achieve this? Mapping the function of the
"Home/Pos1" key to the handwheel? With halui? Or any of the other UIs?
A script or whatever?
Any ideas welcome.
AS
net pdnt.button.w-home whb.button.w-home halui.joint.selected.home
Any ideas welcome.
AS
08 Oct 2021 12:41 #222546
Replied by andypugh on topic Zero axis with handwheel (w/o WCS) possible?
I think that the halui.joint.selected.home pin is meant to start the homing sequence. Not much good without home switches.
However, I am very confused by "One machine though, a very big wood portal machine, cannot use WCSs" because if the machine is controlled by LinuxCNC then surely it can use WCSs?
08 Oct 2021 22:38 #222599
by AkkiSan
as far as I know. But I might be wrong and would love to try this.
How can I execute this command? The error I get is that this cannot be executed
in MDI mode. Tried several thing to leave it, but I don't understand much if not to
say basically nothing of the LinuxCNC internals.
Replied by AkkiSan on topic Zero axis with handwheel (w/o WCS) possible?
If "HOME_SEARCH_VEL" is set to 0, the axis values just becomes 0 without moving anything,I think that the halui.joint.selected.home pin is meant to start the homing sequence. Not much good without home switches.
08 Oct 2021 22:57 #222605
I would suggest using the halui pins to issue a G-code G10 instruction to move the coordinate system rather than re-homing.
That certainly _can_ be done in MDI mode.
linuxcnc.org/docs/2.8/html/config/ini-co....html#_halui_section
For each MDI_COMMAND there is a HAL pin that will cause that G-code command to be run.
09 Oct 2021 00:00 #222612
by AkkiSan
Oh yes, I learned about this a couple of days ago and this is exactly
what I managed to set up (but don't want to do).
How about this one here:
linuxcnc.org/docs/2.8/html/man/man1/sendkeys.1.html
Your name's on that one, so you probably know it very well
Can this be somehow triggered from a handwheel?
10 Oct 2021 02:02 - 10 Oct 2021 02:05 #222706
by AkkiSan
Ok, I quickly learned some HAL and figured it out.
In case anyone needs to zero the axes with this WHB04 thingy, here's how:
Might not be the best way, but considering that I did not understand a single HAL
command or instruction two days ago - it's probably not too bad.
The stuff above also take into account that the default or proposed code,
from the WHB04 manual page, has this line here, which needs to be deactivated:
loadrt and2 count=3
addf and2.0 servo-thread
addf and2.1 servo-thread
addf and2.2 servo-thread
loadrt or2 count=1
addf or2.0 servo-thread
net pdnt.mode.joint whb.halui.mode.joint or2.0.in0
net akki-joint-1 whb.button.w-home or2.0.in1 and2.0.in1 and2.1.in1 and2.2.in1
net akki-joint-out or2.0.out halui.mode.joint
net akki-zero-x and2.0.out halui.joint.0.home
net akki-zero-y and2.1.out halui.joint.1.home
net akki-zero-z and2.2.out halui.joint.2.home
# net pdnt.mode.joint whb.halui.mode.joint halui.mode.joint
Last edit: 10 Oct 2021 02:05 by AkkiSan.
12 Oct 2021 22:13 #222978
For extra reliability you might want to additionally and2 the halui.joint.N.home with halui.mode.is-joint to prevent a race-condition.
That way the home commands won't be issued until the mode has switched.
Time to create page: 0.106 seconds
