halcompile problem
08 Oct 2021 13:45 - 08 Oct 2021 13:47 #222550
by bkt
halcompile problem was created by bkt
I try after long time to compile a new kinematics type .... so i try:
[/code]
k@k:~/linuxcnc-dev/src/emc/kinematics$ sudo halcompile --preprocess rotarydeltakins-k2020.c
Unrecognized file type for mode preprocess: 'rotarydeltakins-k2020.c'
But obtain warning/error messages ..... but file exist on that folder ... so not understand whats happens.
halcompile is installed:
[code]k@k:~$ locate halcompile /home/k/linuxcnc-dev/bin/halcompile .... ....
thanks for any help
Last edit: 08 Oct 2021 13:47 by bkt.
08 Oct 2021 16:19 #222559
by bkt
Replied by bkt on topic halcompile problem
08 Oct 2021 22:45 #222601
Replied by andypugh on topic halcompile problem
--preprocess converts .comp to .c, so if the file is already .c, there isn't anything for it to do.
The following user(s) said Thank You: bkt
