Problably found a hal bug
06 Nov 2021 21:03 #225528
by Grotius
Problably found a hal bug was created by Grotius
Just to let the developpers know.
When i load this text in a hal file, everything is ok :
setp hal_kinematic.0.1.joint-type 2
When i load this text in a hal file, it will not set the value:
setp hal_kinematic.0.0.joint-type 2
When i set the value outside the hal file with halcmd, everything is ok.
I suspect there is a tiny error in the reading .hal files script, i could not find any other explenation for this.
06 Nov 2021 21:15 #225530
by Grotius
Replied by Grotius on topic Problably found a hal bug
Time to create page: 0.066 seconds
