Emco lathe - c11 breakout + 7i92 help with spindle setup
21 Nov 2021 01:16 - 21 Nov 2021 21:05 #227137
by blitz355
Emco lathe - c11 breakout + 7i92 help with spindle setup was created by blitz355
Hello All,
I'm struggling in my early journey to learning linuxcnc. I recently purchased an emco lathe conversion with a simple c11 breakout board ( manual here)
I'm not sure the next steps I need to take. Pncconf shows me two connectors, each have an 'unused pwm' signal. I'm guessing I pick the connector 1 item & then two unused inputs for the forward and reverse functions for the vfd. Does it matter which 'pin' I pick?
From all I read, pncconf only gets you so far and you need to dip into HAL hand editing. I watched a few videos but it isn't clear to me what items I need to edit. What is my next step?
So far I have I flashed my mesa board with 7i92_C11Gx2D.bit file successfully, and have been able to get both axes, x and z moving under there own power.
Thank you to all willing to help.
Dan
Here is my emco_lathe.hal file:
# Generated by PNCconf at Fri Nov 19 20:09:02 2021
# Using LinuxCNC version: Master (2.9)
# overwritten when you run PNCconf again
loadusr -Wn pyvcp pyvcp -c pyvcp [DISPLAY](PYVCP)
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=2 num_pwmgens=2 num_stepgens=3"
#setp hm2_7i92.0.pwmgen.pwm_frequency 20000
#setp hm2_7i92.0.pwmgen.pdm_frequency 6000000
#setp hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
loadrt abs names=abs.spindle
loadrt lowpass names=lowpass.spindle
addf hm2_7i92.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf abs.spindle servo-thread
addf lowpass.spindle servo-thread
addf hm2_7i92.0.write servo-thread
setp hm2_7i92.0.dpll.01.timer-us -50
setp hm2_7i92.0.stepgen.timer-number 1
# external output signals
# external input signals
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.000500
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# Step Gen signals/setup
setp hm2_7i92.0.stepgen.00.dirsetup [JOINT_0]DIRSETUP
setp hm2_7i92.0.stepgen.00.dirhold [JOINT_0]DIRHOLD
setp hm2_7i92.0.stepgen.00.steplen [JOINT_0]STEPLEN
setp hm2_7i92.0.stepgen.00.stepspace [JOINT_0]STEPSPACE
setp hm2_7i92.0.stepgen.00.position-scale [JOINT_0]STEP_SCALE
setp hm2_7i92.0.stepgen.00.step_type 0
setp hm2_7i92.0.stepgen.00.control-type 1
setp hm2_7i92.0.stepgen.00.maxaccel [JOINT_0]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.00.maxvel [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-vel-cmd <= joint.0.vel-cmd
net x-output <= hm2_7i92.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i92.0.stepgen.00.position-fb
net x-pos-fb => joint.0.motor-pos-fb
net x-enable <= joint.0.amp-enable-out
net x-enable => hm2_7i92.0.stepgen.00.enable
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
# AXIS Z JOINT 1
setp pid.z.Pgain [JOINT_1]P
setp pid.z.Igain [JOINT_1]I
setp pid.z.Dgain [JOINT_1]D
setp pid.z.bias [JOINT_1]BIAS
setp pid.z.FF0 [JOINT_1]FF0
setp pid.z.FF1 [JOINT_1]FF1
setp pid.z.FF2 [JOINT_1]FF2
setp pid.z.deadband [JOINT_1]DEADBAND
setp pid.z.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror 0.000500
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
setp hm2_7i92.0.stepgen.02.dirsetup [JOINT_1]DIRSETUP
setp hm2_7i92.0.stepgen.02.dirhold [JOINT_1]DIRHOLD
setp hm2_7i92.0.stepgen.02.steplen [JOINT_1]STEPLEN
setp hm2_7i92.0.stepgen.02.stepspace [JOINT_1]STEPSPACE
setp hm2_7i92.0.stepgen.02.position-scale [JOINT_1]STEP_SCALE
setp hm2_7i92.0.stepgen.02.step_type 0
setp hm2_7i92.0.stepgen.02.control-type 1
setp hm2_7i92.0.stepgen.02.maxaccel [JOINT_1]STEPGEN_MAXACCEL
setp hm2_7i92.0.stepgen.02.maxvel [JOINT_1]STEPGEN_MAXVEL
net z-pos-cmd <= joint.1.motor-pos-cmd
net z-vel-cmd <= joint.1.vel-cmd
net z-output <= hm2_7i92.0.stepgen.02.velocity-cmd
net z-pos-fb <= hm2_7i92.0.stepgen.02.position-fb
net z-pos-fb => joint.1.motor-pos-fb
net z-enable <= joint.1.amp-enable-out
net z-enable => hm2_7i92.0.stepgen.02.enable
net z-home-sw => joint.1.home-sw-in
net z-neg-limit => joint.1.neg-lim-sw-in
net z-pos-limit => joint.1.pos-lim-sw-in
# SPINDLE
setp pid.s.Pgain [SPINDLE_0]P
setp pid.s.Igain [SPINDLE_0]I
setp pid.s.Dgain [SPINDLE_0]D
setp pid.s.bias [SPINDLE_0]BIAS
setp pid.s.FF0 [SPINDLE_0]FF0
setp pid.s.FF1 [SPINDLE_0]FF1
setp pid.s.FF2 [SPINDLE_0]FF2
setp pid.s.deadband [SPINDLE_0]DEADBAND
setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
# ---PWM Generator signals/setup---
setp hm2_7i92.0.pwmgen.00.output-type 1
setp hm2_7i92.0.pwmgen.00.scale [SPINDLE_0]OUTPUT_SCALE
net spindle-vel-cmd-rpm => hm2_7i92.0.pwmgen.00.value
net spindle-enable => hm2_7i92.0.pwmgen.00.enable
net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-vel-cmd-rpm <= spindle.0.speed-out
net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-enable <= spindle.0.on
net spindle-cw <= spindle.0.forward
net spindle-ccw <= spindle.0.reverse
net spindle-brake <= spindle.0.brake
net spindle-revs => spindle.0.revs
net spindle-vel-fb-rps => spindle.0.speed-in
net spindle-index-enable <=> spindle.0.index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.1.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-number <= iocontrol.0.tool-prep-number
# ---ignore tool prepare requests---
Dan
Last edit: 21 Nov 2021 21:05 by andypugh.
21 Nov 2021 17:39 #227208
Replied by andypugh on topic Emco lathe - c11 breakout + 7i92 help with spindle setup
Do you have the correct firmware flashed on the 7i92?
You need this so that the PWM step/dir outputs etc appear on the correct pins to drive the C11 board.
There are a couple specific firmwares for the C11. You probably want "7i92_C11Gx2.bit"
21 Nov 2021 20:52 #227230
by blitz355
Replied by blitz355 on topic Emco lathe - c11 breakout + 7i92 help with spindle setup
Hi Andy,
I had typed that info in my orginal post but must have deleted somehow. I updated my original post. But yes I have:
So far I have I flashed my mesa board with 7i92_C11Gx2D.bit file successfully, and have been able to get both axes, x and z moving under there own power. So I'm pretty close already, only need a spindle and limit switches before I make chips!
21 Nov 2021 21:10 #227232
The spindle control looks like it ought to be working, assuming that the C11 is connected to the same pins as the PWM module.
There is the skeleton of a spindle PID but that seems not to be included in the loop at the moment (which is fine)
If you MDI "M3 S1000" and look at the PWM duty cycle and enable in halshow do you see what you would expect?
21 Nov 2021 23:03 #227244
by blitz355
Hello,
I will need to figure out how to do all those things and report back…
When you say “assuming that the C11 is connected to the same pins as the PWM module.” You’re referring to the 0-10v connections on the c11? Or are you referring to the two outputs that control fwd and reverse in the vfd wired to my c11?
Thanks for your support
Dan
Dan
21 Nov 2021 23:13 #227247
There are specific pins on the D-sub of the C11 that are connected to the filter that makes 0-10V from the PWM input.
Then there are specific pins on the D-sub of the 7i92 that the PWM comes out of, and which those are depends in the firmware.
If you start LinuxCNC from the command line then I think you get a pinout listing. That might help. Just use the command "linuxcnc" then proceed as normal.
You can start Halshow from the menu of many of the GUIs. Which one are you using?
All of the above, really.When you say “assuming that the C11 is connected to the same pins as the PWM module.” You’re referring to the 0-10v connections on the c11? Or are you referring to the two outputs that control fwd and reverse in the vfd wired to my c11?
22 Nov 2021 03:10 #227267
by blitz355
Ah ok great! I will verify wiring. The previous person who did the conversion had all working for mach3 so it should be wired right
I have it set up to run on gmoccappy
Dan
Dan
22 Nov 2021 13:36 #227294
HAL Meter might be the simplest to use as it always shows live values. HalShow needs to have the watch-tab configured to show live values, but shows several pins simultaneously.
In the setup tab Gmoccapy has buttons at the bottom to start the HAL tools: Halshow, Hal Meter and HAL Scope.I have it set up to run on gmoccappy
27 Nov 2021 03:02 - 27 Nov 2021 03:09 #227721
by blitz355
Hi Andy,
I was able to look at this some more tonight.Some developments so far - I was able to 'wire up' a couple more outputs via pncconf and got the spindle fwd and rev functioning. From gmoccapy gui I can start and stop the spindle. However I don't have spindle speed control
A couple things first - I was looking at how my vfd was wired to the c11 breakout boards 0-10v terminals. Originally the c11's 0-10v pin was connected to vfd "Ai1" (Analog input 1), and the c11's ground (next to 0-10v) to vfd 10v terminal. That didn't make sense to me so I switched the ground from the c11 to be connected to the ground on the vfd. After the change, no success after a test and adjusting the spindle percentage slider.I did however experience at some points an 'UU' error on the vfd. Research tells me this is under voltage error on the input (odd?)I also decided to put a multi meter across the ground and 0-10v terminals on the c11 bob. Turn the spindle on in gmoccapy, I'm reading around .144vdc regardless of on/off. Pretty sure I should be getting alot more voltage - this leads me to believe the pinouts on the mesa aren't connected to the c11 correctly virtually (more likely) or via hardware (unlikely?).
Now, on the hal meter side. I'll confess, I don't totally understand what parameters I should be monitoring to show fault or function. I snapped a couple pictures of and posted here.
-2 potentially unrelated items to getting the spindle functioning:
1. Image 5 appears when I start linuxcnc for the first time using my profile. I don't recall if it happens immediately or only once I start jogging axes / spindle
2. Unrelated to the spindle I have an x limit /home microswitch and spindle pulse encoder (1 pulse per rev). The x limit is connected to pin 10, and spindle pulse encoder is 15. In the pncconf g540 setup I'm not given the option to select those functions. This is something I'd like a hand on at some point as well. Spindle at this point is more important though!
Thanks Again!
Thanks Again!
Last edit: 27 Nov 2021 03:09 by blitz355.
27 Nov 2021 21:29 #227777
In the pictures I see that the spindle speed is showing -100.
Try starting the spindle in the other direction.
You probably want to link to the absolute speed output from motion.
( spindle.0.speed-out-abs ) and then switch the VFD direction separately (if you even plan to support reverse rotation)
Time to create page: 0.117 seconds
